Home > Orders (L405) > Help and Advice NEEDED - Factory order has arrived WRONG :( |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 654 |
Turn it of and on ( the ignition I mean). Same happened to me and it then righted itself. |
18th Jun 2017 9:43am |
nickcruise1 Member Since: 23 Jan 2013 Location: Essex Posts: 16 |
mine did the same yesterday and has done it a couple of od times, but not enough to
25th Jun 2017 10:59pm |
syl Member Since: 24 Jan 2017 Location: Somerset Posts: 30 |
That one's not a mistake. The solid goes all the way across. The belt is intended to sit on one side or the other. If using the belt and the solid divider at the same time, you would have three anchors on one rail and one anchor on the other. I used the belt to secure a Calor gas canister the other day. First time it's come in useful. |
25th Jun 2017 11:48pm |
1strangerover2017 Member Since: 11 Jun 2017 Location: Cambridgeshire Posts: 76 |
Thank you for this, on other manufactures I have the same type of system in the boot and the tension strap allows the belt from one side to the other and some tolerance to allow for a shaped object, when I raised with the dealership they advised that they needed back to replace - perhaps they needed to have advised me of its function! |
26th Jun 2017 8:23am |
According to JaguarLandRover customer services the dealership have rejected my rejection, but I have received NOTHING from the dealership, no phonecalls, no emails etc!
30th Jul 2017 8:14pm |
I have had my new Range Rover 5 months today and still the wrong headlining, I have rejected the vehicle and the dealership are refusing to accept my rejection!
23rd Aug 2017 10:18pm |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 769 |
A nightmare for such an expensive vehicle bought new.
23rd Aug 2017 10:48pm |
Hi Phil,
23rd Aug 2017 11:16pm |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 |
To successfully reject any item but especially a car you need to stop using it and return it to the supplying dealer IMMEDIATELY you can not just keep using it ! You might have had a small chance of them re ordering your car on day one as you collected it but as for 5 months down the line sorry to say that no matter how much you jump up and down you wont get anywhere now . |
24th Aug 2017 12:01am |
Hi Charlie,
24th Aug 2017 5:07am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
Again it is disappointing that your initial negative experience has been compounded by the problems sourcing the right headlining, and the poor client relations performance on the part of the dealer and LRCR.
24th Aug 2017 1:47pm |
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 395 |
If the supplying dealer is reasonably close call them up and find out when the Dealer Principal is going to be in and go and visit personally for a meeting.
24th Aug 2017 2:04pm |
I'd go easy on the shouting etc, you'll just get thrown out. After all, it's not the dealer's fault that LR misbuilt the car, or that LR sent them the wrong headlining/damaged headlining. Only Range Rovers since 1988 |
24th Aug 2017 3:05pm |
Thank you, I had said that I would be rejecting the car in the first month and they assured all would be resolved ....... well does not look like it! |
24th Aug 2017 3:38pm |
