Home > Maintenance & Mods (L322) > DPF Full Warning
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
What is the Turbo Drain mod guys.. I also like the power every now and then when I rev up getting onto the motorway to the slip road there is a massive smoke cloud is that because of the 2nd turbo kicking in? Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #443261 2nd Jul 2017 10:07am
basically yes.....
there is an issue with the secondary turbo drain which means that the oil in the turbo bearings remains under pressure when the car is off. This bleeds past the bearing into the turbo and hence the cloud of smoke.
there is a fix for it and LR will generally do it under warranty, however its about £1000 if its not.
to avoid the smoke just use the second turbo regularly.... Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #443265 2nd Jul 2017 10:42am
Baltic Blue
Not sure that The 3.6 tdV8 suffers the same turbo drain fault as the 4.4 tdV8. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443268 2nd Jul 2017 11:04am
scotcruz
cheers.. I'm surprised there was mention of this anywhere.. mine is out of warranty anyway so guess I need to keep an eye.
what's the best way of keeping the 2nd turbo kicked in regularly? Current:
Past:
Post #443270 2nd Jul 2017 11:05am
stu
The 3.6 is set up differently to the 4.4 so I wouldn't unduly worry about this! Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443275 2nd Jul 2017 11:27am
scotcruz
Cheers Stu.. I take it 3.6 doesn't a twin turbo? Current:
Past:
Post #443277 2nd Jul 2017 11:38am
stu
http://www.fullfatrr.com/forum/post319625.html
Yes both twin turbo just different setup Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443279 2nd Jul 2017 12:01pm
Sorry missed that scotcruz had a 3.6.
So no that drain mod is not applicable Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #443282 2nd Jul 2017 12:51pm
scotcruz
panic over lol.. Current:
Past:
Post #443283 2nd Jul 2017 12:53pm
stu
Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443288 2nd Jul 2017 1:09pm
Scotcruz Would have a quick look at the top turbo hoses (take them off takes 5 mins) as a starter 4 ten just to check they aren't starting to split and give the MAF a clean. Black smoke is generally overfuelling so that would be where I would start. If everything checks out then i wouldnt worry too much. There is nothing that can't be fixed with a hammer😜😜
Post #443290 2nd Jul 2017 2:04pm
