Home > Maintenance & Mods (L322) > Advice on fitting brake pads |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 |
I will check the disks as well. Interestingly no vibration or noise to speak of today after getting worse for the last two months. |
26th Jun 2017 7:12pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3194 |
It may well have been down to not removing the protective coating on the discs. See if the improvement continues. John
26th Jun 2017 7:14pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Webbie , do not put grease on the back of the pads . rubber sleeves on the caliper pistons do not like grease. |
27th Jun 2017 7:05pm |
Thanks for the nod to the wise. His will be a Saturday morning job now. |
28th Jun 2017 8:18pm |
Webbie, have you sorted the brake problems? |
7th Jul 2017 8:54pm |
Check your rear discs and pads for excess heat after a run, (spit on the disc after a couple of mins) if it sizzles you have a finding calliper
7th Jul 2017 9:13pm |
Problem resolved:
8th Jul 2017 12:03pm |
