Home > Maintenance & Mods (L322) > TDV8 Diff and Trans oil |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
but reluctant to my VIN code and it's up for everyone to see as it shows the last search Current:
30th Jun 2017 9:42pm |
Picked up the oil from LR and changed the transfer case oil today.. Man that was satisfying.. dont think the oil had been changed since it was manufactured.
11th Jul 2017 8:57pm |
Keith A Member Since: 25 Oct 2012 Location: Sherborne, Dorset Posts: 105 |
Haven't done the front on mine yet as it's a 14mm drain plug key, which I didn't have.
11th Jul 2017 10:20pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
yes the front is fiddly! i would suggest an extension and UJ on your ratchet or i used the 1/2" drive handle i got with my caravan motor mover as it has a gentle curve in it which gave enough clearance from the sub frame. Also when you crack the fill plug on the front, i used a 14 mm ratchet spanner on the allen key socket to turn it quicker and easier. My old fat fingers not so agile these days... Current: TDV8 (3.6) RRS HSE
12th Jul 2017 12:56pm |
cheers guys.. wish there was a video which showed the oil change as its always good to know what you are up against while u are under the car.
13th Jul 2017 12:28am |
There are videos on you tube for diffs and trans box! Current: TDV8 (3.6) RRS HSE
13th Jul 2017 8:07am |
I found the transfer bix ones for 3.6 TDV8 but non for front diff.
13th Jul 2017 8:23am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
it is worth noting, when changing differentials and transfer box oil to undo the filler plugs before draining the oil. just in case
13th Jul 2017 11:57am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3680 |
Good tip Nino.
13th Jul 2017 12:05pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
cam-tec-craig always banged on about that... ... - .- -.
13th Jul 2017 12:32pm |
credit where credit is due , tks. stan , i could not remember who it was. BB some things are best learned from somebody else experience |
13th Jul 2017 1:55pm |
Easy to do (just done mine).
13th Jul 2017 5:53pm |
did you undo the splash bar that's infront of the drain plug? Current:
13th Jul 2017 9:35pm |
Nope. Just the undertray to come off. Current cars:
13th Jul 2017 10:40pm |
