Home > Maintenance & Mods (L322) > Drivers Door Handle |
It was -8 here last night and no problems with frozen locks for me |
30th Nov 2010 4:46pm |
-11 last night where I was north of Spean Bridge. Door locks all worked fine and no misfiring when I started the RR today |
1st Dec 2010 3:58pm |
Mine is away as bad as before ................... Lube stuff worked for two days ............ |
1st Dec 2010 4:27pm |
This wasn't you trying to get in the car was it Mick? |
1st Dec 2010 4:36pm |
1st Dec 2010 4:40pm |
Did you have to break it free |
1st Dec 2010 5:25pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
elpeede, you got it spot on mate..the water does indeed get in via the window trim, runs down a 'runner' straight onto the lock mechanism.. the only way to sort this ,is to remove the lock assembly completely and dry it out and lubricate inside the lock and the cables . ... - .- -.
2nd Dec 2010 10:09am |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
SO far ok with only one moment where the door lock failed to come up.. different cable!
4th Dec 2010 5:40pm |
Two days back i sprayed WD40 White Grease inside the lock with the tube/straw attachment so far so good .... |
4th Dec 2010 5:43pm |
it appears the correct answer could be to rub a sheep over the latch mechanisim or buy some sheep water proofing in a pot http://www.flints.co.uk/acatalog/Marine_Lanoguard.html 2010 Disco XS TDV6, 2009 Freelander 2 GS
6th Dec 2010 3:16am |
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 |
My drivers door cable also failed last Friday just as I was leaving for work, I've had to live with it for a week as I've been away in Warcop and Catterick - muchos bummer!!!
24th Jun 2011 11:13pm |
DougBLC Member Since: 23 Jul 2016 Location: Barton-Le-Clay Posts: 6 |
Nearly 5 years since this posting, but looks the most likely link to my problem. 2011 TDv8VSE rear o/s passenger door stopped working suddenly, cant open from outside or inside handles. Remote lock works fine, is this most likely cable snap?
10th Aug 2016 4:38pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
Just had my 07 TDV8 drivers side go, same thing couldn't open it from the outside, no resistance on the handle.
14th Nov 2016 8:58pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
great thread this! Had my external door cable go the other day so searched and found this thread: followed it to a tee and got everything off in 35 mins only to find when trying to put the new cable end into the slot that it won't go! so had to take the door locks off (great powerful Uk youtube vid BTW!) to see why not, only to find the old broken end of the wire is firmly and irrevocably seized in the hole! Have tried drilling it out to no avail.
13th Aug 2017 10:29pm |
