Home > Maintenance & Mods (L322) > oil type please ! |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
if the oil level is above max. line i would take 1/2 l of oil out. easiest way is by vacuum pump.
24th Aug 2017 5:46am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
The gauge is remarkably sensitive. If the display screen shows the level at the top of the permitted range I would just leave it and monitor occasionally, if the car is using lots of oil it would be worth checking why, mine has never needed to be topped up in over 50,000 miles, it's not like say a 200 series Land Cruiser. If the car is showing the oil above the permitted range when the car is cold and on level ground it might be worth getting a workshop you trust/dealer to extract some. Only Range Rovers since 1988 |
24th Aug 2017 3:18pm |
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 88 |
Thanks for all the replies, greatly appreciated.... I need more help than most...sorry !! |
24th Aug 2017 4:37pm |
