Home > Wheels & Tyres > Tired Tyres
Page 2 of 4 <1234>
gizze
I would take Kumho tyres over Continental, which have to be the most over priced tyre on the market imho.
Noisy, wear badly and start to break down well before 5 years is up. Porsche 911 (996)
2015 BMW 5 Series Touring
Not got a LR of any kind at the mo, and got itchy feet.
Post #452672 1st Oct 2017 11:01pm
Billaboard
United Kingdom 2004 Range Rover Vogue Td6 Baltic Blue
This is now getting ridiculous. The tyres on the wheels that I was looking at in the scrapyard were manufactured in 2002 and 2004.
We looked at the wheel lug nuts on the car, which are the type from an original 2004 FFRR, and the scrap seller said he thought they were right for the existing wheels on the car. But if the wheels were, as described when I bought the car, RR Sport wheels, these nuts should have been the wrong type.
So I drove to the local, recommended by many, indy LR repairer, and he said that the wheels are, in fact original 19" Range Rover wheels and so the nuts will be correct for them. He just thought keep these wheels and buy a spare off ebay. So, the question is can anyone idenify what the wheels on the car actually are so that I can match them and not buy a spare that needs different wheel nuts.
Here, I hope, is a picture.
 Old 110 2.3 Petrol ???? - ????
Old 110 200tdi ???? - 2004
1996 Discovery 300tdi 2004 - 2015 met fiery end being welded
2004 JEEP Grand Cherokee 2015 - 2017
2004 L322 Td6 2017 -
Post #452707 2nd Oct 2017 1:09pm
gizze
The early wheels, up to around 2005 use a different nut to the later ones.
The wheels you have in your picture should be using the early type black nut if from a FFRR or the later silver type if they are from a RRS I would guess.
They look like the silver ones from your photo. Porsche 911 (996)
Post #452709 2nd Oct 2017 1:43pm
billboard, you have RRS wheels which should have the 23mm shank nuts (as in the 2005 onwards FF)
the correct FF tyre size is 255 55 19......
you can put the above tyre size onto the RRS wheels.... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #452710 2nd Oct 2017 1:49pm
Billaboard
Well, the current tyres are definitely 255/50 R19. The wheels are as shown above and the wheel nuts, which have a 20mm shank, look like this. Is everything wrong?
I've ordered a single wheel nut with possibly (it didn't say!) a 23mm shank from ebay. I will offer it up when it arrives. Old 110 2.3 Petrol ???? - ????
Post #452720 2nd Oct 2017 5:09pm
gizze
When you put your finger in the wheel, the hole where you removed the bolt, is it bevelled or flat? Porsche 911 (996)
Post #452741 2nd Oct 2017 6:56pm
Billaboard
Gizze, that would mean taking the wheel off completely, which I was hoping not to have to do.
I assume the bevel, if not just there for identification purposes, is just a simple guide as, surely, the main tightening force on both types of nut is between the flat part of the nut where the washer is and the wheel itself.
All this would be much easier if I had a spare wheel to look at, but that's partly where I came in. Old 110 2.3 Petrol ???? - ????
Post #452764 2nd Oct 2017 8:53pm
gizze
No, just stick you finger in the hole where you took that wheel nut out of.
Can you feel a taper on the inside of the hole or is it flat?
There is a reason wheel nuts are tapered, it is because the holes you are putting them in are also tapered. Porsche 911 (996)
Post #452777 2nd Oct 2017 9:43pm
gizze
I should just add, the reason it seems a bit strange is Stan is saying your wheels are RRS wheels, your wheel nuts however are early FFRR wheel nuts.
I guess the early nuts will fit as they are smaller, where as you would not be able to use the later nuts on earlier wheels as they would not fit.
Have you had any problems with vibrations or anything?
Just with them being 3mm smaller than needed to line them up properly it could be quite easy to not have them completely central.
I suppose the tapered aspect is more for wheel bolts than wheel nuts. Porsche 911 (996)
Post #452783 2nd Oct 2017 9:56pm
Rob99
Wheel nuts are not designed to locate or centre the wheel on the hub. Wheels are a close tolerance fit via the protrusion of the hub into the centre hole of the wheel. Wheel nuts alone, no matter how torqued up would not be sufficient to hold the wheel central to the hub if it weren't for the protrusion. 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #452796 2nd Oct 2017 11:25pm
Billaboard
The thing is that these are lug nuts, so, when removed from the wheel, the bolt is still there in the centre of the hole, so there's no way of sticking a finger down.
The bigger nut is due to arrive by Thursday, so I hope that offering that up will clarify matters.
Two ebay adverts for RRS wheels have pictures that match my wheels, so I'm sure that Stan is correct.
A friend with a Disco2 (who uses and trusts the local indy who said they are FFRR wheels!) has looked at the wheels and a nut and he, too, wondered whether I had any vibration problems. I haven't noticed any, but.....
Simultaneously with this I've been having suspension knocking noises attended to and my local man has replaced 2 "stabilising link bars". This has massively helped, but there are still occasional lesser clunks so I'm wondering if any of these might be slight movement of the wheels under the nuts.
Edit: Just seen Rob's contribution, which implies it doesn't matter if these are the wrong wheel nuts. I think I'm too old for all this Confused
The Disco friend was very proud that his nuts were bigger than mine. Rolling Eyes Old 110 2.3 Petrol ???? - ????
Post #452798 2nd Oct 2017 11:39pm
gizze
Unnecessary quote removed
I know it shouldn't matter, and the centre hub is usually down to 0.1mm accurate, but I did wonder if having so much play with the bolts if maybe there had been some issues.
But you're right, I guess it shouldn't matter as the hub will always pull it central. Porsche 911 (996)
Post #452799 2nd Oct 2017 11:45pm
gizze
I never get why I always get "Unnecessary quote removed" when I am replying and it is not the person directly above me but to an earlier poster?
I think the quote helps keep the thread in context far better and causes less confusion. Porsche 911 (996)
Post #452830 3rd Oct 2017 11:10am
its a conversation...you dont repeat what someone has said before you reply to him...
my job is to keep the 'conversations' flowing and to delete quotes that dont need to be there... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #452843 3rd Oct 2017 2:09pm
Rob99
That's not what I'm saying. You absolutely should always use the correct wheel nuts.
The point I was making is that the transfer of the weight of the car happens through the hub/wheel close fit. Correct wheel nuts are essential to bolt the wheel to the face of the hub. 2017 4.4 SDV8 Autobiography
Post #452844 3rd Oct 2017 2:16pm
Page 2 of 4 <1234>
