Home > Technical (L322) > Front suspension dropping overnight |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 799 |
there are lots of things that can cause this issue pal , corroded pipework , reservoir leaking but I guess the fact that both are equally dropping suggest the front valve block or related to that part of the system is at fault |
18th Oct 2017 5:39pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2312 |
Mine has the same ailment yet has only travelled 65K kms I concluded that the front cross-link valve was leaking to atmosphere so bought a kit. However I only replaced 2 of the 3 o-rings because the smallest appeared too small but that should still have stopped the lowering if the valves had been leaking from both sides to atmosphere. However 1 side could be leaking and the cross-link valve not sealing properly between the 2 sides. The cross-link valve doesn't look to be well designed but good enough for its intended application except if one air-spring leaks over time. |
19th Oct 2017 4:40am |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 83 |
Thanks Bembo, I need to see what is available locally for the valve block.. |
19th Oct 2017 6:43am |
Graeme thank you, I cannot make out if your valve block repair did the trick for you, please let me know.. Did you purchase the o-ring kit for LandRover or was it from a different supply source?? Crazy as this sounds our local LR charge 20% handling fee on order cancellations, so I will still take the bags as already paid for, as long as they are late year manufacture date, and possibly replace or keep in store.., will probably consider the valve block as well while I am in there, but if an o-ring seal is available for LR then I will first go that way.. Front left front diff output is leaking as well so with everything stripped down I will have an opportunity to replace the axle seal as well, luckily the Fattie is not my daily driver so she can stand on jackstands for a few days extra.. |
19th Oct 2017 6:49am |
Replacing 2 of the 3 cross-link valve O-rings did not fix mine but perhaps if the 3rd O-ring was changed then it may have. I didn't change any O-rings for the 2 corner valves so I may have another attempt once I've contacted the supplier to question the cross-link valve's smallest O-ring's suitability.
19th Oct 2017 7:22am |
Many thanks Graeme, I will order the o-rings as a precautionary measure, worth a shot at that price, and shelve the project until I get everything together as one lot.
19th Oct 2017 8:42am |
Yes, I understand that the o-rings as the top of the strut are problematic due to the swivelling shaft especially on older vehicles but I would expect dropping on 1 side initially and perhaps a year or 2 later the 2nd side too.
19th Oct 2017 9:53am |
No, seems I was wrong in my analogy, the o-rings simply seal, they do not rotate against the strut, the entire bag rotates with the strut on an upper bearing plate of sorts..
20th Oct 2017 2:11am |
I thought that I had found the cause of mine's front dropping overnight when I found bubbles escaping from one of the pins in the electrical connector on the front valve block. However a new, confirmed not leaking valve block didn't cure the problem but soapy water with the suspension fully extended revealed the cause - one air-spring is porous all the way around near the base.
4th Aug 2018 3:39am |
