Home > Maintenance & Mods (L322) > Aftermarket supercharged front grill
anorakmark
United Kingdom 2004 Range Rover Vogue Td6 Epsom Green
Good evening all.
Has anyone purchased one of the aftermarket front grills from www.powerfuluk.com
I have been looking at the chrome & silver replacement supercharged grill part no RRG336-CS @ £95.00
Unfortunately these grills do not come with the oval Land Rover badge, although they do supply a replacement aftermarket black supercharged badge @ £13.00. Anyway my question is does anybody know if the original badge from my grill will fit into the replacement grill? Powerfuluk have given me the dimensions of their badge as 91mm x 48mm, I have just measured my original OEM badge which measures 91mm x 40mm so their appears to be a slight difference. If anybody has purchased one of these any advice would be great. Powerfuluk do not sell replacement green & gold badges to match the rear badge & wheel caps they only sell the black supercharged aftermarket ones.
Post #454440 18th Oct 2017 6:00pm
Flyingfocrs
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
I have the black grille but decided to fit the black/silver badges to go with the theme, from memory you need the stick on tailgate badges from a Disco, i’ll pop out and measure it in a bit
Post #454441 18th Oct 2017 6:13pm
anorakmark
Thanks flyingfocrs, yes you are spot on, just been looking on the web.
The original OEM badge on the RRFF measures 86mm x 43mm, the after market grill takes a 91mm x 48mm and yes it looks like it's the rear badge that fits on these. If you could supply me your measurements that would be great as I want to keep my green & gold oval.
Looks like Land Rover part no DAH100680, if you could confirm I have this correct.
Thank you for your kind help.
Regards.
Mark Very Happy Very Happy Very Happy Very Happy
Post #454444 18th Oct 2017 6:31pm
Flyingfocrs
I fitted OEM land rover black/silver badges and my front one is 86 x 43 on the replacement grille.
Post #454550 19th Oct 2017 12:31pm
anorakmark
Thanks flyingfocr for your time & help on this one.
Regards.
Mark. Thumbs Up Thumbs Up
Post #454585 19th Oct 2017 4:16pm
Shaun_
Hi. I recently bought one from Hawke and am really pleased with the quality. Mine is a later model but I think you're looking at something like this
http://shop.sixonetwo.co.uk/range-rover-vo...grey-.html
Seems cheaper and they do supply a genuine black and silver badge included in the price. 2012 TDV8 Westminster in the New Forest
Also: Land Rover Series 3 SWB, Mercedes 280SL, Classic Mini race replica, VW Golf SV
Previously: Audi A8, RR TDV8 Vogue, Audi Allroad, VW Golf GTI Edition 30, Audi A4 Avant, A8, A4 Sport, A6, VW Golf Mk5, Bora, Golf GTI Mk3, Jetta Mk3, Passat, Jetta Mk1, Golf Mk1
Post #454587 19th Oct 2017 4:31pm
anorakmark
Thanks Shaun, having a look now.
Regards.
Mark Thumbs Up Thumbs Up
Post #454589 19th Oct 2017 4:38pm
Flyingfocrs
My grilles
Post #454593 19th Oct 2017 5:16pm
anorakmark
Looks great flyingfocr, certainly enhances appearance Thumbs Up Thumbs Up
Post #454594 19th Oct 2017 5:20pm
holidaychicken
You still leaking Mark?
You have seen mine but I don't personally like the grilles that cover over part of the headlight and make the wipers stick up in the air.
Post #455189 24th Oct 2017 8:42pm
anorakmark
Hi Andy, how is you.
Yes still leaking HELP!!!!
Hey bought the grill, went for the silver & grey one mate, will get a pic tomorrow. I had to buy the badge separately from Duckworths as I wanted to keep the green & gold oval to match the ass and hub caps. Grill looks good mate.
As for the leak GRRRRRRRRRR!!!! LOL Rolling Eyes Rolling Eyes Rolling Eyes Rolling Eyes
Right I have narrowed the leak fright down as I been playing with my hose Very Happy Very Happy Very Happy
The water is peeing in from the upper tailgate left hand side. It does not appear to be the seal>
I think it's either the upper tailgate hinge plate or the body seem where the weld runs along the top.
Got the hose out and first I drenched the bottom tailgate & bumper area and all dry excellent job you done, thank you.
I then started to move up to mid upper tailgate and all dry, side windows all good no leaks, then went to the top off side where spoiler meets roof and stuck hose in there and all dry. And finally upper tailgate near side where spoiler meets roof, hose in the gap on full pelt for 2 minutes. I then opened tailgate and water dripping in the left hand bulk head in the corner where that little apreture / hole is. So it's deffo coming in at the top, have put little bits of silicone around bolts on upper hinges but still getting water ingress???? think we are nearly there but need your experetese mate Very Happy Very Happy Very Happy Very Happy
Post #455193 24th Oct 2017 8:52pm
anorakmark
Unnecessary quote removed
Same here Andy, the ones that give you a 2005 conversion are horrible, having to move the bloody wipers, I went for the standard square on too, well pleased with it, looks good, will send you a piccy on here tomorrow mate. All is good except that dam leak Big Cry Big Cry Big Cry LOL
Post #455195 24th Oct 2017 8:56pm
holidaychicken
You are getting there, when I was tracking mine down I put a big dollop of grease in places to see if it cured the leak and then went back and sealed it when all was dry. With the grease you can liberally cover large areas and then wipe it off if it doesn't cure it. But you know all that as I put a dollop on yours !!
The TD6 on my drive has a cured injector , remove and repair door mirror next ....
Post #455203 24th Oct 2017 9:13pm
anorakmark
Is the one on your drive a second Rangie or a job your doing mate, you have the patience of a saint mate. Very Happy Very Happy
Post #455204 24th Oct 2017 9:22pm
holidaychicken
It's a mates , long story short he lost his only key and then tax and MOT ran out and mr plod wanted to take it away as on the path outside his house and on a sorn so I took it in...
Post #455207 24th Oct 2017 9:31pm
