Home > Technical (L322) > Enabling TPMS using IID Tool |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34917 |
do you have the tpms valves fitted to your wheels Chris? ... - .- -.
13th Nov 2017 2:39pm |
carpcat Member Since: 13 Oct 2017 Location: Surrey Posts: 58 |
I do Stan including the spare. I first tried a random setting in Tyre Pressure Monitoring 1 which then bought up the option on the dash settings for TPMS, but after driving it said TPMS was not available. Theres about 20-30 different options that I can choose, but dont know which one... Chris |
13th Nov 2017 2:46pm |
another question chris, were these the original wheels/tyres or something you bought after... ... - .- -.
13th Nov 2017 2:51pm |
Its a strange one Stan. Ive got the original spare but the 4 main tyres are from another RR. I dont know whether they were the same year. So yes this could be the issue, but if I knew the right settings I could know for sure. Chris |
13th Nov 2017 2:56pm |
i see what you mean about all the different iidtool settings re tpms ,
13th Nov 2017 3:20pm |
..........forgot to add,
13th Nov 2017 4:30pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6657 |
You must be the first person to want to enable TPMS, most people find it very unreliable and produces false alerts. Got - 2017 SDV8 Autobiography in Loire Blue
13th Nov 2017 6:20pm |
Thanks Stan. Looked at my build on VIN site and it has TPMS installed. I have tried your settings suggestion and it at least now has the TPMS Warning light come up during ignition on the dash during the light check, so a good start! I guess I need to drive a bit for the system to register the valve sensors. Chris |
13th Nov 2017 10:53pm |
sounds like a plan Chris.. ... - .- -.
13th Nov 2017 10:54pm |
Blair Member Since: 03 Apr 2017 Location: Suffolk Posts: 72 |
I've been having issues with mine since fitting 2016 wheels and sensors. I believe they changed the sensors around 2014, and the new ones won't work properly with an older car.
14th Nov 2017 10:22am |
Simsy53 Member Since: 11 Nov 2018 Location: Essex Posts: 1 |
Anybody no the settings in the ccf to reactivate tpms in a 2011. |
12th Nov 2018 5:53pm |
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 |
Oddly I had been having issues with the original TPMS system on my 2007 RR, it operated occasionally but mostly it showed a TPMS system error, I changed all the sensors for new but it made little difference, just recently I fitted a set of take offs (2018 20”) from Dan, since then my TPMS system has been much more reliable......so not sure what’s going on here. David
12th Nov 2018 6:04pm |
