Home > Maintenance & Mods (L322) > To flap or not to flap?
Page 2 of 3 <123>
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
finchi wrote:
Turbulent air flow at rear causes dirty rear screen. Having flaps minimises the amount of mud, grit, and dust that is sucked up.
Thanks. Would love to see an animation of how the air flows around. What do I put here then?
Post #457482 16th Nov 2017 12:03pm
Weegie
Like this?
 John
GAP iiD BT
Post #457488 16th Nov 2017 12:29pm
GAC23
Yes. But with a FFRR. What do I put here then?
Post #457491 16th Nov 2017 12:40pm
Weegie
It will be pretty much the same as any other car, especially estates. The flatter the back the more turbulence is created with corresponding vortices which "curl" the air flow up the rear of the vehicle.
Can't see a FF specific video. John
GAP iiD BT
Post #457506 16th Nov 2017 1:50pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
No flap will help this time of year
Post #457513 16th Nov 2017 2:39pm
GAC23
Thanks for the explanation. And looking for a FF video.
Still fascinates me how the dirt must get blown around. What do I put here then?
Post #457516 16th Nov 2017 3:24pm
bishbosh10
I flapped and don't regret it.
Had fronts on when I got her and added rears after I saw the state of the rear 1/4's after a short run.
If I am honest I prefer the look without mudflaps at both ends but equally honestly, I don't notice they're there now. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #457548 16th Nov 2017 8:51pm
j_rov wrote:
It's a shame they require drilling of bodywork, otherwise I'd try them out...
It's a big decision as once they are on, they have to stay on....
You don’t need to drill the holes in the bodywork to fit the mud flaps!
The idea of the drilled holes are to:-
A, pull them tight into the bodywork (BUT, use a good quality double sided tape and that will do the same)
B, rigidly fix them for off road use (BUT, if you don’t use/work it off road then they are an overkill IMHO)
Oh and NO mine does NOT have them as i think they are ugly! Wifeys D4 does as they are smaller and more descreet Thumbs Up
Post #457568 17th Nov 2017 12:30am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Only have my 2011 a few weeks and it came without rear flaps but the amount of dirt on the rear quarters forced me to put on flaps. I orefer without but i dont notice they are there.now. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #457575 17th Nov 2017 8:08am
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
An advantage of flaps is that they reduce spray, in the wet, at high speed and are therefore a road safety feature. For example if you take a look, HGVs are fitted with big flaps and also the inside lining of the flaps have a mesh or multi-spiked surface. This is to reduce spray and is very effective.
Post #457589 17th Nov 2017 12:47pm
j_rov
Still undecided! Opinion seems to be 50/50!
Maybe i should put the money towards more regular car washes! __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #457633 17th Nov 2017 7:13pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I took mine off whilst I replaced the side steps & although I initially liked the look without steps & flaps. I still prefered the look with them & side steps.
As previously stated keeps a lot of road dirt off the vehicle & aides entry / exit if they are used correctly. Still educating the other half Rolling Eyes
PS Don't fit rear ones Thumbs Up
Post #457641 17th Nov 2017 7:57pm
Vogue
I have had 16 Range Rovers, some with and some without flaps.
IMHO they look crap, they are useless, cost money, spoil the looks of the car, spoil resale value, and make not one jot of difference keeping the car clean. The only purpose they serve is stopping stone chips on a trailer behind. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #457642 17th Nov 2017 8:16pm
CS
I have flaps front and rear. They don't stop the back of the car getting dirty. As others have said that is just a product of the shape of the car, likewise one should avoid driving with the tailgate open and the windows closed as then exhaust fumes get sucked into the car. The flaps are good at reducing the amount of mud, stones etc thrown along the side of the car (front ones) and behind (rear) the latter being relevant also to convoy driving off road (risk of stones being thrown at following vehicle). With all terrain tyres more is thrown, and further, making the flaps more desirable.
Vogue makes a good point about the flaps reducing the amount of debris thrown at trailers - they certainly don't eliminate it though, mine is always clattered with mud etc after off road towing. Only Range Rovers since 1988
Post #457644 17th Nov 2017 8:22pm
unsolicited
United Kingdom 2017 Range Rover 5.0 SC V8 Mariana Black
One thing no-one has mentioned. I found that rear flaps affect straight-line stability at - ehem - 'continental' cruising speeds. I removed the ones mine came with and the difference is really night and day.
Post #457817 19th Nov 2017 12:54pm
Page 2 of 3 <123>
