Home > Technical (L322) > Rear brake pipes |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
Depending on how far gone they are, someone on here recently had theirs coated. Could be a cheaper option?..? |
12th Dec 2017 11:00pm |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 668 |
Get some recommendations for locsl independent land rover specialists.
12th Dec 2017 11:10pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34930 |
you could try doing it yourself,
12th Dec 2017 11:14pm |
Paul,
12th Dec 2017 11:16pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 498 |
I had a similar quote from main dealer, I asked how much was the b/pipe. At the time it was about £28 the rest
12th Dec 2017 11:39pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2217 |
I had them done at my local garage as part of service including rear calliper carrier and tota bill was less than half that |
13th Dec 2017 7:01am |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 90 |
Having done the job a couple of times (I run a garage ) to do it properly with copper or cunifer it takes about 4 to 6 hours to do properly (lots of trim to remove) and run them right to the joints in the front wheelarch so should be about £300 to £400 at sensible labour rates , bit of a faff though . |
13th Dec 2017 10:40am |
SidewaysMatt Member Since: 25 Feb 2016 Location: Ledsham, Cheshire Posts: 173 |
I had to have the rear ones that are part flexi / part solid done for the last MOT - genuine LR ones used and it cost ~£150 including fitting if i remember correctly. 2004 Vogue TD6 - Remapped
13th Dec 2017 3:11pm |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 354 |
I've done quite a few of these and it's not a huge job if you have the pipe flaring kit etc.
13th Dec 2017 5:04pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
My indie did the repair with copper in less than an hour including tea !! 2015 4.4 AB
13th Dec 2017 5:10pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1245 |
I'm just about to do the job on the driveway. The tool is about 30quid. The copper pipe about 30 quid , and I bought a tray of unions for 20quid.
13th Dec 2017 7:04pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
It is worth removing the front inner wheelarch covers on the front left (RHD passenger side) - especially the smaller one against the engine bay (this will probably break on removal ).
13th Dec 2017 10:56pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Would strongly suggest following Joe90 advice. I did mine back in February as one had split under the tank cover. The short connector pipes in the LH wheel well were nearly shot as well. 56 TDV8 Vogue SE
13th Dec 2017 11:13pm |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 220 |
Has anyone tried buying the genuine LR rear pipes and cutting and flaring the O/S pipe to make fitting across the rear subframe easier? 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
14th Dec 2017 10:10pm |
