Home > Range Rover Classic > Hello World! |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3674 |
Miggit,
22nd Dec 2017 4:55pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
^ I beg to differ with you bud, Lucas and the associated connectors that were used in the RRC are prone to corrosion and all the faults that floating earths and ECU's can cause.... At the end of the day the RRC isn't very waterproof for a car that's branded as swimming in deep water.
22nd Dec 2017 8:23pm |
DavidL Member Since: 14 Nov 2013 Location: wiltshire Posts: 140 |
Don't convert it to coils Tim, what a waste. They are very nice on air. The valve block and compressor can be rebuilt at home with a new seal kit, the drier is available new and the reset software is FOC on the net. You need a funny 3 pin lead which you can make or buy for about £30. Alot for a lead but there you go.
23rd Dec 2017 12:23am |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
Thanks for the insight Miggit. My experience is OEM parts solved many an issue but I take what you say, at the end of the day these things have a mind of their own anyway. Its true what you say about swimming to. I drove steadily through an 18 inch ford once and the thing just stopped in the middle. Luckily it started and we continued but as you say for a car billed as capable I'm not that confident.
23rd Dec 2017 10:40am |
As far as I'm aware the LSE had a lot in common with the P38 EAS, again possibly not the best setup, let down mainly by the quality of the electrical components used....
23rd Dec 2017 11:47am |
It is but if you note the date is 2010. That's when I bought it and its still at the vendors house down on the south coast. I think its the only pic I have in working condition! RR decal is gone now after a front end respray. The car had gone through 3 or 4 of the committee of the rrr but the forum is a dead loss and I'm not a FB user so I've let it go. The soft dash air system is virtually the same as the p38. Main difference is that the p38 has the pump under the bonnet whereas the classics has it in a box under the sill! Great to get to. The pumps are subtly different but I'm sure can be modified. I've seen cars with twin pumps which seems a sensible idea to keep the wear and tear down. |
23rd Dec 2017 4:42pm |
"forum is a dead loss and I'm not a FB user so I've let it go" Exactly!. Why does the world have to revolve around social media!
23rd Dec 2017 7:16pm |
Tim-LR Member Since: 21 Dec 2017 Location: Suffolk Posts: 5 |
I'm going to keep it as standard. Rear crossmember and boot for have been welded. Currently dealing with the bulkhead and inner wings. |
23rd Dec 2017 8:43pm |
I'm definitely keeping the EAS. I've made the cable and got the software. It looks low because when I got it it had been sitting for 13 years! It needs 4x new air springs at least (one has completely popped of its mounting). Yours looks very nice. I think I recognise it from on Landyzone? My bulkhead has rusted very similar to yours. I think we should manage to weld it up for now but I'll probably send it away in the future to have it sorted properly (nice and expensive I imagine). I've got new sills and body mounts waiting to be fitted, just need to find the time. I did have a thread on the LRO forum for it but the forum seems to have been deleted and now redirects to facebook. |
23rd Dec 2017 9:21pm |
jemj Member Since: 13 Sep 2012 Location: leighton Buzzard Posts: 54 |
Hi David, yes you are right, it is a 24 spline diff fitted to your LSE. They are now starting to get a bit like hens teeth due to so many classics being used and abused off road but they are still available. If you get stuck, let me know as I have a few contacts with various classic RR's in various stages of repair / disrepair. The Best 4x4 by far, so long as you have deep pockets. |
13th Mar 2018 8:58pm |
Hi Guys, whilst I love my L322 to bits I still love the Iconic father of all RR's, the classic. I have owned, run as a daily and driven to destruction in Comp safari racing and trials many of the classic models. The old Land rover slogan ' The Best 4x4 By Far' certainly was the best.Here are just a couple of my classics, sadly no longer with me though
13th Mar 2018 9:15pm |
annette Member Since: 07 Nov 2018 Location: Tilarán Posts: 30 |
Here you can see..
15th Nov 2018 5:34pm |
Cool!
15th Nov 2018 7:14pm |
Sure you can say cool.. that is what I say in that stream
15th Nov 2018 7:32pm |
