Home > Technical (L322) > Heated Seats Keep Turning Themselves Off? |
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 816 |
Thanks Steveball - Although my issue is a bit different, for the most part it works fine and when the seat goes off, so does the dash light.
24th Dec 2017 11:26am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3654 |
I'll get the seat out over Christmas and see if its broken as described by others first, if so I'll try the "fix" as this costs nothing but time then if it doesn't I'll be back on here asking for part numbers for a new unit. I feel that its a bit more sensible approach rather than pressing the panic button and sourcing a new unit now. Geoff |
24th Dec 2017 6:05pm |
The good news is I got the seat out and the back off and located the busted pipe. The bad news is it's just started down so I have had to cover everything with a tarp and get back to it. Its worth noting that getting the seat out is not quite as simple as it seems, I had to drill a hole to release the seatbelt and disconnecting multi plugs is always a pain. Geoff |
29th Dec 2017 3:18pm |
So I fixed the busted pipe as others have done - BUT no joy as the fault remains. So I'll try swapping the ECUs but I'm not optimistic so I'm bracing myself for another big bill Geoff |
31st Dec 2017 4:30pm |
