Home > Maintenance & Mods (L322) > Re-Map????
Page 2 of 4 <1234>
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
If he had 40's on he wasn't getting 28mpg in the first place. The speedo over reads on standard tyres about 8% on new tyres. Increases as they wear. The speedo was over reading nearer 16-17% on 275/40's. Probably around 20% when worn. Showing 40 mph when the car was doing nearer 32/33 mph. So the Odometer was also over reading.
275/ 40 = 110 mm x 2+ 508mm gives the diameter x 3.14 = 2285 mm rolling circumferance.
508mm being a 20" rim
255/50 r 20 is standard. Gives 2395mm rolling circumferance
255/55r 20 is 30mm higher sidewall. So 60mm overall height. They give 2475 mm rolling circumferance.
That's 190mm or nearly 4" difference. Add to that 6mm of extra tread and it's even more.
It will affect the computer readout but not real MPG.
Holding the gears will, of course, affect MPG. Maybe get the gearbox ECU remapped. That will sort it.
The speedo will now be just about spot on.
Re-map the gearbox and you will get accurate MPG and a nicer drive too Thumbs Up 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #461883 22nd Dec 2017 10:56pm
Paul thornton
^^ very well explained^^
My thoughts exactly plus it will probably be holding lower gears for longer.
Post #461884 23rd Dec 2017 12:07am
bob-lad
Verbosely explained but not quite correct.
275/40/20 = 110mm sidewall
255/55/20 = 140mm sidewall
An increase of 30mm, not 4" - If you're talking about sidewall height.
If you're talking about circumference then
the 275/40R20 are 90"
the 255/55R20 are 97.5"
so 7.5" not 4"
Post #461886 23rd Dec 2017 12:13am
Grofus
Yeah my mistake. 100mm is 4" . The Circumferance is increased by 190mm. 200mm being 8". 30mm extra side wall x 2 for diameter = 60mm.
60 x 3.14 = 188.4 mm Add 12mm for the tread depth on new vs old tyres. Then you have 72mm x 3.14= 226 mm or about 9". Thumbs Up
I know 9 extra inches in the wife's box would certainly mess it up Rolling with laughter Whistle
Anyway, maths aside this my help.
https://www.4x4australia.com.au/gear/1710/...explained. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #461889 23rd Dec 2017 12:49am
Andyyav
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
Fantastic info!
I will check the turbo hoses and investigate the gearbox re map, anyone had one done?
Post #461900 23rd Dec 2017 11:57am
Andyyav
Ive had the top two hoses off no apparent damage, they were replaced just before I bought it about 10 months ago, any more I should check?
Bespoke remap starts at £350 locally, I’ve to discuss the finer details with them tomorrow 👍
Post #463169 3rd Jan 2018 7:50pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
bespoke remap ? are they going to rolling road it then pal ?
Post #463172 3rd Jan 2018 7:56pm
Andyyav
Yep rolling road custom remap, they give it a health check to see what’s what and what’s do-able, then check it all again after, they also offer a stage1 one remap offering an extra 30 Bhp and 100NM of torque for a lesser price but I prefer the idea of the bespoke remap to fit the car, lifetime guarantee on software or any problems related to the remap too
Post #463181 3rd Jan 2018 8:28pm
bembo449
blimey pal , seems a bit OTT on a 4x4 to me but let us know what you think ? obvs going to be a big improvement over standard , are you fitting free flow filters or anything to make the most of the map ??
Post #463183 3rd Jan 2018 8:31pm
Andyyav
Guess I’ll see what they say about filters etc, I’m more interested in the gearbox working less as it’s hanging in the gears after the tyre change to be honest,
Post #463187 3rd Jan 2018 8:38pm
bembo449
hmmm , well I guess the rolling radius has grown due to new tyre depth but im surprised its altered how the transmission responds pal ?
Post #463188 3rd Jan 2018 8:40pm
@andy, you'll need a rolling road that accommodates both the rear and front axles at the same time .. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #463191 3rd Jan 2018 8:43pm
Grofus
Have you tried resetting the gearbox ECU. They learn driving habits so a reset on the new tyres maybe worth a try. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #463192 3rd Jan 2018 8:45pm
Andyyav
@stan they’re aware it’s a FF if they’ve not thought if that I’m off!!
@grofus how do I carry a reset out?
Post #463195 3rd Jan 2018 8:56pm
bembo449
that would be hilarious if they've given you all the shpiel and they don't actually have a 4WD RR to map it on Laughing Laughing Laughing
Post #463197 3rd Jan 2018 8:59pm
Page 2 of 4 <1234>
