Home > Technical (L322) > Battery rcommendations for a 2005my TD6 |
NVB Member Since: 14 May 2017 Location: Essex Posts: 103 |
I need yet another replacement battery for my L322. Last time I fitted a Yuasa 5000, which replaced the previous yuesa 3000. I do have a parasitic drain of about 250ma, which I need to be to the bottom of, but what battery is the current recommendation for this model?
6th Jan 2018 7:35pm |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 456 |
AGM's are for the 405's is my understanding.
6th Jan 2018 11:14pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I just fitted one of these to my mates TD6 2006 RR and it’s been great so far and cranks it over like it’s starting a moped.
7th Jan 2018 1:41am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Bosch and Varta are the same factory, only the bosch is more dosh. VARTA is what LR fitted in the factory, so instead of fitting a LR battery with a little Vatra badge and a big price tag, fit Varta battery without the LR bit and save around 50%
7th Jan 2018 9:40am |
Well shockingly fleabay turned out to be the best price that I could find
7th Jan 2018 9:56am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7797 |
I still rate Euro Parts - they replaced my3 year old Bosch without a quibble
7th Jan 2018 10:04am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1276 |
varta 020 from tayna failed within 18 mths for me
7th Jan 2018 10:28am |
7th Jan 2018 10:32am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34949 |
the 020 type is the best battery for the td6 and if possible get from someone local in case it fails .. ... - .- -.
7th Jan 2018 11:04am |
Right chaps, listen up......
7th Jan 2018 12:05pm |
cough cough
7th Jan 2018 1:31pm |
So why do the 2011-2012 ffrr's charge at 14.7 volts? Yesterday I couldn't spell Engineer... Today I are one!
7th Jan 2018 3:24pm |
I am still very much drawn to an AGM after doing lots of online research. I don't think the charging regime of a 2005 L322 will cause an AGM any problems. Having said that, Miggit does put up a very compelling argument for the Varta above, so I will give the Varta a whirl this time and try an AGM next, if I need to replace it again. Thanks all for your input. RR History 1988 2.4td Classic 1999 to 2020 1992 3.9efi Westminster Classic 2004-2005 2005MY L322 3.0TD6 Vogue 2016 to current |
8th Jan 2018 3:45pm |
unsolicited Member Since: 30 May 2016 Location: London Posts: 123 |
I had an 020 AGM in (Varta H15), that failed within 12 months. This is in a 2007 SC. If you go AGM make sure you can return it locally. |
8th Jan 2018 7:45pm |
