Home > Maintenance & Mods (L322) > Howto: FFRR '02 TD6 - Change a Diesel Injector |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
A fairly straight forward job, but a lot of dismantling required to get at the injectors, and a few tips that go against what RAVE says!
17th May 2014 9:50pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Thanks, I see you didn't have to go to these lengths to get the injector out. |
18th May 2014 7:05am |
I was worried, knowing my luck, and the fact they had been in there 12 years, but they behaved for me, unlike my glow plugs, three of which are well and truly f*****d ! .
18th May 2014 12:28pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34917 |
nice job tim, wiki'fied. ... - .- -.
18th May 2014 12:35pm |
18th May 2014 1:14pm |
I've just had my glow plugs done by Craig - 5 were not working at all, and the 6th was hardly working. It still started (just) after being parked outside overnight in -8.5°C. Just don't go anywhere very cold and you'll be ok. |
18th May 2014 1:50pm |
Ah, fuel return connectors arrived, fitted new to pipes and bolted everything back together. A bit of a struggle to start up initially but now starts on the turn of the key. Chatatatata solved! No leaks either! No complaints from Message Centre.
19th May 2014 9:02pm |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 146 |
Guess I was lucky to get the injector very easily out (previous owner had the engine rebuild three years ago and also removed injectors, so where not stuck or rusted).
3rd Aug 2016 4:55pm |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
Just to add to this, following a suggestion from CamTechCraig I loosed of the retaining nuts on the injectors about 1 turn and then started the engine.
16th Jan 2018 11:00pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Yep, I did the same on mine. Nice little trick. |
16th Jan 2018 11:07pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
I must have been lucky all mine came out with a slight twist if the injector, non of the horror stories of others. |
17th Jan 2018 7:38am |
Just to add to Joe's excellent post (again), I managed to replace all my injectors really easily apart from No.1 which was absolutely solid. After hours or tapping from side to side, gently leveraging, running the engine with it loose and soaking in releasing agent it would not budge.
2nd Apr 2018 12:18pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
I’m just doing mine. I’ve got the plenum chamber off and undone the injector pipes.
26th Nov 2018 3:20pm |
Depends if you go new LR, new aftermarket, or refurbs
26th Nov 2018 3:34pm |
