Home > In Car Electronics (L322) > Problems with the sat nav, sometimes!
Tight777
Sometimes it works fine, other times no.
First it always has Belgium as the host country, I change it, its fine then I'm back in Belgium.
Sometimes I change from north up to direction and it freezes.
Sometimes it won't come off the "Don't use whilst driving or you'll die" screen, so I can't use it at all.
Are there any updates or later discs that may help?
Late 2007 spec.
Post #468326 12th Feb 2018 10:11pm
Pvw10
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Yes 2017 ones exist google is your friend.
The disc is only read, I had similar once and it wasn’t the disc sadly. Many thanks
Paul
Post #468456 13th Feb 2018 4:29pm
Tight777
Thanks wasn't sure if the later discs would work in an older system, I'll keep a look out.
I must admit I tend to use waze on my phone any.
Post #468466 13th Feb 2018 5:36pm
dingg1
mod edit, link deleted...
please do not link to illegal sat nav discs as this is against forum rules..
Post #468469 13th Feb 2018 5:58pm
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
