Home > Maintenance & Mods (L322) > FBH disabled? |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Do you have an IID tool? 2015 4.4 AB
17th Feb 2018 3:23pm |
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 89 |
Unfortunately not, I’ve had the codes read before and it’s never been mentioned, can the tool turn it off without registering an error? |
17th Feb 2018 3:42pm |
It proberbly not turned off but the screen controls can be activated by the tool. 2015 4.4 AB
17th Feb 2018 3:44pm |
My 07s FBH worked if the car was running ( it cut in once
17th Feb 2018 3:52pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2213 |
From memory the diesels all have one and they cut in when the temp is below 12 or 13 deg c to help the engine get up to temp quicker whether they are all turned on so that they can be manually used dont know - Think that is why the bulk head valve is not there The valve stopes the engine being warmed up so that the interior can be |
17th Feb 2018 7:21pm |
Appreciate all the reply’s some great info!
17th Feb 2018 9:53pm |
The two valves on the side are restricted flow one for each side and they work on the return not the feed again it is a while since I did all this and mine is a petrol but the cooling system is nearly identical |
17th Feb 2018 10:39pm |
My guess is that the drivers side is not opening fully if you take the engine cover off and the pollen filter box off you can access all the pipes and feel which is getting warm and which is not |
17th Feb 2018 10:41pm |
Rich_Allen Member Since: 05 Jan 2015 Location: Rutland Posts: 76 |
Where abouts in Norfolk are you? 2008 TDV8 Vogue SE
18th Feb 2018 5:01pm |
About 30 mins east of Norwich, you? |
18th Feb 2018 11:24pm |
I’m over in Stamford, but come down to burnham market every now and again as my mum lives over there...
19th Feb 2018 12:16am |
A very kind offer, I’m thinking of investing in one myself as I’ve a ‘lumpy’ idle issue....... |
20th Feb 2018 11:00pm |
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 297 |
the lumpy issue will probably be an faulty injector mine was you can get them repaired as replaced saving you ££ |
4th Mar 2018 7:45pm |
Would a faulty injector throw up a code?
4th Mar 2018 7:52pm |
