Home > In Car Electronics (L322) > Ignition controlled supply |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
there's a couple of 'electrical wiring' links in the wiki tha might help.. ... - .- -.
24th Feb 2018 4:46pm |
Biggles1957 Member Since: 05 Dec 2017 Location: Leicestershire Posts: 28 |
Thanks for the swift reply Stan. I've found one in there that talks about making the auxiliary socket in the boot ignition controlled using a relay - which is exactly what I was thinking of doing to my sat nav unit. So that is the green and yellow wire above the rear fuse box (is that on the near or offside?). That's fine - but I'm trying to find out which is the existing ignition controlled supply to the DVD sat nav drive. I know the red and green is the battery feed - so you can eject the disc and so on without the ignition on, but I'm having trouble finding which wire is the ignition controlled one. At this stage, I'm not sure if it is the sat nav itself that is at fault - or if the supply to it is the culprit. If the weather is OK tomorrow I shall have a good poke about! |
24th Feb 2018 4:59pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Purple and white wire from fuse 8 is the ignition feed. |
24th Feb 2018 7:05pm |
Aha! Smashing! Thanks |
24th Feb 2018 7:12pm |
You could try pulling fuse 49 to see if your battery drain goes away whilst it's out. |
24th Feb 2018 7:33pm |
Well.....it seems to me from what I can see in all the electrical info and diagrams etc., that the sat nav unit only has a permanent live feed from the battery and not an ignition controlled one at all. Ditto the amplifier and stuff. Can anyone confirm this please?
25th Feb 2018 11:37am |
Definitely an ignition wire, purple and white. You need to go to page 183 of the wiring diagrams to see it. |
25th Feb 2018 12:03pm |
