Home > Technical (L322) > Help - Judder under light breaking |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 |
I have had a problem with judder under breaking for about six months now. The disk and pads were new Land Rover and about six months old at the time the judder started. Following a suggestion from another FFRR forum member I Tried scrubbing off the pads with some brisk breaking and initially thought this had worked, but I was kidding myself.
14th Mar 2018 6:20pm |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 668 |
You need the discs checking for Disc Thickness Variation (DTV) - which is often a cause of judder.
14th Mar 2018 7:02pm |
Thanks for the replies, I haven't looked at the rear brakes at all and they are still the originals at 80K miles. |
14th Mar 2018 8:12pm |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
I had juddering too that was eventually eliminated by replacing the rear discs and pads having already replaced the fronts along with the lower suspension arms.
14th Mar 2018 9:05pm |
If they are the originals at that mileage then they are due for a change, but I would also check the calipers aren’t binding.
14th Mar 2018 9:24pm |
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 73 |
I had this too. But I know exactly what caused it on my L322 - a bent brake disk.
14th Mar 2018 10:46pm |
