Home > Technical (L322) > Turbo Waste Gate |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Thanks for the extra tips.
23rd Feb 2016 7:41pm |
I could probably have done a bit more bending of my hook and got there. I thought someone had put a picture on of the access to the actuator, but couldn't find it
24th Feb 2016 9:03pm |
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 |
Can you remember what sort of angle you went with the wire to get to the arm? I can hook the thing but only at such an angle from over the subframe that its probably at about 45 degrees below horizontal so when I pull its pretty much trying to pull the arm backwards not downwards if that makes sense. Have soaked it in wd40 anyway to see if loosens of its own accord but struggling to actually get meaningful leverage onto the actual horizontal arm or join.
21st Apr 2018 8:17pm |
Once you hook the arm it is push down rather than a pull 56 TDV8 Vogue SE
21st Apr 2018 8:54pm |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 |
I used a heavy gauge coat hanger, straightened out, and did some heavy duty prodding.
23rd Apr 2018 10:42am |
This is the problem, if you pushed it surely you made the arm go up from horizontal? Other people are saying push it to go down and am not sure which way it should go as mine is very seized it seems. The drivers side one has no resistance at all with the engine off and would easily move with a prod but want to try to find out which direction the passenger side one moves before re attempting to move it
23rd Apr 2018 11:09am |
Just keep stabbing at it and trying the ignition (which will perform the self test of the actuators)
23rd Apr 2018 11:37am |
Yeah no perceived change in performance.
23rd Apr 2018 11:59am |
Davidmudley Member Since: 27 Dec 2021 Location: Surrey Posts: 80 |
This is a really helpful thread. I have this issue with a FFRR (2011 TDV8) I’m collecting next week so I’ll put my prodding skills to the test!
27th Dec 2021 8:15am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2681 |
This thread describes an issue with the TD 3.6 and yours will be the 4.4 which has a totally different turbo setup. What exactly is the issue you are having? 2012 TDV8 Vogue (L322) |
27th Dec 2021 9:09am |
The passenger side boost actuator is stuck, it sounds exactly the same issue as has been described.
27th Dec 2021 9:55am |
Stuck open or closed? any fault codes ? Who diagnosed this? ( Never heard this being an issue on the TD 4.4) 2012 TDV8 Vogue (L322) |
27th Dec 2021 10:16am |
It was diagnosed by the garage of the seller. It goes into limp mode when accelerated hard, triggering fault P004B and I believe the actuator in the closed position.
27th Dec 2021 10:29am |
I also understand it may just be a leaking pipe. |
27th Dec 2021 10:30am |
