Home > Maintenance & Mods (L322) > Rear wiper, is this correct |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 508 |
Doesn't look right - mine certainly parks more neatly. 2016 Skoda Octavia VRS Estate
11th May 2018 4:43pm |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
It should tuck under the spoiler when in he parked position. It actually lifts the blade slightly away from the glass too, so that it doesn’t stick in freezing weather. Makes it awkward to swap the blade actually, requiring good timing to open the top boot at just the right moment to stop the blade mid-wipe. Current: 2010 Range Rover L322
11th May 2018 4:45pm |
Nelly Member Since: 02 May 2018 Location: Hampshire Posts: 118 |
I did think it should, so not sure what the issue is now, is /should the sweep be symmetrical? |
11th May 2018 4:48pm |
Not symmetrical. Hopefully the glass is dirty enough for you to see the wiper sweep on mine.
11th May 2018 4:52pm |
Yeah I can see that thanks,, I don't think this wiper has as much movement |
11th May 2018 4:54pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7633 |
I can only suggest removing the wiper arm when it’s in the park position and putting it back on so it’s under the spoiler. Think you have to remove the spoiler to get to the nut, so might be best doing when you investigating wiper motor issues or such like....
11th May 2018 5:23pm |
OK will do, I'm taking the rear apart tomorrow anyway so will have a better look |
11th May 2018 5:28pm |
