Home > Technical (L322) > Acoustic Windscreen?
Voguevague
Greece 2006 Range Rover Supercharged 4.2 SC V8 Santorini Black
Land Rover
Pilkington
CCC E000204
E1 43RR-001588
AS1M1260DOT682
Looking for help please, I have a cracked/chipped windscreen.
When making claim and discussing with the kind lady from Autoglass this morning it looks like it is a replacement needed and not a repair.
The details as on the cracked windscreen are as above, it looks like the original, though she asked is it an 'Acoustic'.
Appreciate one of you experts informing me if I have an 'Acoustic' screen fitted as above or not..
How do I tell please
Thank you, Keith.
Post #478452 15th May 2018 9:21am
mpirie
I seem to remember there being a speaker symbol etched near the type numbers if it''s acoustic.
Have a search through the forum to be sure.
Mike
Post #478454 15th May 2018 9:58am
rjff
Hi Keith
Your text details are slightly different but if it has the two marks in the photo below it may well be acoustic, these also appear on the door windows, vindecoder (https://www.vindecoderz.com/) may assist. Perhaps a message to Dan at Duckworths or the Land Rover Customer Care thread on the board may assist.
This is a shot of the screen markings on our 2011 showing the acoustic and heated marks at the bottom
If you have unlimited cover for glazing on your car, then you should be able to have the acoustic screen fitted for the excess you have to pay, assuming you are not doing this from your own pennies. Do insist on Land Rover marked glass, as you may be fobbed of with only the Pilkington mark. We recently had a side door window replaced and that was covered, but it took a week to get the OEM LR marked glass. It may also help in reselling with original glass as it would be proper Land Rover marked glass.
Hope this helps
Richard
Post #478455 15th May 2018 9:58am
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Re: Acoustic Windscreen?
Unnecessary quote removed
I thought the M1260 needed a -1 after it to denote an acoustic screen.
But this may not be true.
The other thing to look for is an ear symbol.
This post explains it all: http://www.fullfatrr.com/forum/topic36415.html What do I put here then?
Post #478549 16th May 2018 8:44am
Voguevague
Thank you for all the help.
Amazingly at 16:55 on the Friday before a Bank Holiday the screen was deemed irreparable by the friendly Autoglass Specialist Technician, who left to go on his holiday.
I then insisted on Land Rover OEM glass at a premium, but in the meantime, my local independent MOT Tester said it is not a fail, being in a part of the screen which is impossible to look through unless the dash was removed and you sat on the floor!
Local screen guy repaired it in 25 minutes for the same in Pounds.
Job done!
Regards, Keith.
Post #482090 28th Jun 2018 12:18pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
That’s funny, Autoglass managed to do the same to a small star crack on mine and a new screen was deemed necessary. I don’t imagine that Autoglass find themselves completing a successful repair that often... Just unlucky, I suppose Whistle
Post #482092 28th Jun 2018 1:31pm
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
What is different on a acoustic windscreen as apposed to a normal screen? 2012 TDV8 Vogue SE 4.4
Post #482126 28th Jun 2018 9:00pm
Red Merle
It helps to deaden noise, but I don’t know how (which is probably what you were asking! Embarassed )
Post #482135 28th Jun 2018 10:35pm
Frans@Yamorna
Correct!Was wondering what is the diffirence between the FFRR screen and our FL2 screen?I was always under the impression that sealing is the way to combat noise on a windscreen.Maybe the RR acoustic one is thicker than normal to combat outside noise? 2012 TDV8 Vogue SE 4.4
Post #482141 29th Jun 2018 6:29am
Red Merle
https://medium.com/@WindshieldExperts/acou...fd7e0313b7
Post #482145 29th Jun 2018 7:01am
GraemeS
This is mine. Yes it is cracked.
Post #482157 29th Jun 2018 8:18am
Call that a crack ? Whistle
Post #482158 29th Jun 2018 8:33am
Kiwimac
New Zealand 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Ouch!
Here in NZ it is very hard to get OEM glass fitted - they use a lot of Chinese stuff which *technically* passes the tests (allegedly) but very few insurers will pay for OEM.
I had a Toyota Alphard hybrid that had a special windscreen that reflected UV etc so that the a/c did not have to work so hard. It got replaced with a bog standard Chinese one and not only were the edges not optically clear (the view bent like a lens) but the heat of the sun on my legs was many times more than it had been with the original Toyota glass.
You used to be able to get away with OEM because the Chinese had not mastered complexities like heating wires in the glass etc but now they can do that.
Post #482245 30th Jun 2018 10:29am
Bill
All that surfing on the internet paid dividends for the Chinese then! Rolling Eyes Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #482253 30th Jun 2018 10:51am
thrillcat
United States 2012 Range Rover HSE 5.0 V8 Santorini Black
Red Merle wrote:
https://medium.com/@WindshieldExperts/acoustic-windshield-helps-in-noise-reduction-2ffd7e0313b7
Wow, that's some incredible glass if it can make that much of a difference in a convertible with the top down!
[/img] 2012 L322 5.0l NA
Santorini Black / Sand
Post #482689 5th Jul 2018 2:39pm
