Home > In Car Electronics (L322) > Airplay vs WMA1000 Tune2Air - best iPhone streamer? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Hi guys,
5th Nov 2017 8:37am |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
Airplay is higher quality than Bluetooth. So an AirPlay solution would be better.
5th Nov 2017 10:16am |
Cheers chaps. EM - I'm unlikely to be near you but a very very kind offer, thank you very much.
5th Nov 2017 12:22pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
Tune2 Air sounds excellent. I'm running it on 2 autos 2014 FF Autobiography 5.0 SC
6th Nov 2017 5:07pm |
Lee Marsh Member Since: 21 Nov 2016 Location: Herts Posts: 44 |
Apple TV could be an AirPlay solution as well. Problem may be the fibre optic is only output rather than through, breaking the MOST chain.
13th Nov 2017 9:13pm |
So Santa brought me a Dolry.
27th Dec 2017 9:48am |
Have tried a couple of streamers and the only one I’ve managed to make work is the tune2air, granted the others were just cheap BT affairs. There is nothing that can't be fixed with a hammer😜😜
27th Dec 2017 10:58am |
So sent back the Dolry Stone.
5th Jan 2018 8:46pm |
Possible solution if you can iron the snags out. There is nothing that can't be fixed with a hammer😜😜
5th Jan 2018 8:56pm |
longmanh Member Since: 11 Feb 2018 Location: Thames Ditton Posts: 104 |
I'm trying to find a solution that works as well as the Tune2Air but struggling.
15th Mar 2018 9:17am |
Nah I haven't read the manual yet!
15th Mar 2018 8:58pm |
An update from my last post: I found out how to get the Neet to work on Airplay, whilst leaving the phone's 4G data connection:
22nd May 2018 1:50pm |
thrillcat Member Since: 04 Jan 2018 Location: Ames, Iowa Posts: 23 |
If you're plugging in via the 3.5mm aux jack, you're not getting AirPlay sound quality. The aux jack is a drop in quality compared to the direct (digital) iPod connection of the Bovee/WMA1000. The aux jack is adding a conversion from digital to analog, then back to digital inside the head unit. 2012 L322 5.0l NA Santorini Black / Sand |
22nd May 2018 8:33pm |
I think you're right thrillcat, I've not been using the NEET for a while, only yesterday when I solved that IP issue. The quick blast I gave it sounded a bit flat compared to the old iPod I've also got hooked up.
23rd May 2018 5:58am |
