Home > Technical (L322) > Deployable step issues |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 420 |
Hi, I mounted original deployable steps to our 07 l322 in August 2015, and the steps have worked fine until this winter. Then a strange “squeeze” noise started appearing on the right hand step when extracting and retracting the steps. I therefore disabled the steps for a while, and now our Indy has looked at it. It seems that the right hand step motor is turning an extra 1/2 turn on each operation, causing the noise from the gears inside the right hand step motor.
29th May 2018 8:23am |
Do anyone know if it’s possible to reset the BCU/BCM that controls the steps? Is that an option with Gap IID tool?
29th May 2018 10:58pm |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 |
Are they proper stepper motors or just motors with limit switches ? I would have thought the latter in which case a tweak to the switch shoud sort it No7 - 2003 V8 Vogue |
30th May 2018 7:26pm |
Gary at FamousFour (where I bought the steps) did speak with LR about this in the beginning of June, but no reply yet. My hope is that there is a way to reset the module that is controlling the step motors, and if that doesn’t work, we have to get the step motors replaced. |
21st Jun 2018 11:56am |
