Home > Maintenance & Mods (L322) > Air suspension fault
moby2004
United Kingdom 2004 Range Rover HSE 4.4 V8 Bonatti Grey
Hi everyone need help/advice .my lovely rangie was running perfect then had suspension inactive warning so bought diagnostic tool , that said front left height sensor fault so cleared it but now front wont adjust up or down and is extremely bumpy and wallows along . What do i need to try ???
Post #480041 3rd Jun 2018 9:27pm
Probably because you have a faulty front left height sensor!
Have a look at it, one of the joints may have parted company, which you can DIY mend with nut,bolt, washers (and tap washers) and spacers. Or check connections and wiring.
Otherwise it will be a new one, unfortunately front ones are twice the price of rears, @ £60
or you could have a leak in the airbag, can you get to offroad height after an EAs reset ? .
Post #480069 3rd Jun 2018 11:56pm
moby2004
thanks for your help and advice turns out it was the front ride height sensor had went over the cam and was 180 degrees out!!
for ince a simple and inexpensive fix lol
Post #481054 16th Jun 2018 12:02pm
