Home > Technical (L322) > Key fob stopped working
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
L322 2003. seems my key fob suddenly stopped unlocking my doors. I replaced the battery, but didn't olve my problem.
The fob light comes on when I press the buttons on the fob. it will unlock the door using the key and will start the vehicle. I did a google on how to sych the key but no luck.
One method said unlock car have doors closed and insert key to ignition turn to pos 1 then back to 0, remove key , press unlock and hold and press lock button 3 times within a certain time no luck, another instruction said same but have vehicle locked when doing the procedure. ,no luck either.
Any ideas?I have another fob that works which I am now using.
Post #480548 10th Jun 2018 7:49am
Sandyt
I have a similar issue I now have one that does everything one that opens doors and starts but no fob and one key that just opens the doors - I have tried local specialist has tried all that happens is the the keys change operation but only one will work on the fob at any time Good luck hope yours is an easier fix
Post #480551 10th Jun 2018 7:56am
Weegie
When you synch the second key you must not put it in the ignition as that starts the cycle over again. Apologies if you were aware. Confused John
GAP iiD BT
Post #480553 10th Jun 2018 8:05am
Keep trying, took me several goes to get it to work:
http://www.fullfatrr.com/forum/post479032.html#479032 .
Post #480567 10th Jun 2018 9:42am
lounge_on_wheels
I didn't sych a second key, as the other key works, I just was trying to sych the one the stopped working.
Post #480730 12th Jun 2018 12:08am
lounge_on_wheels
Update: I managed to get the working key into sych mode with the procedures listed but the second key will not sych.
Post #480868 14th Jun 2018 7:05am
