Home > Technical (L322) > Bad smells, what's about to fail? |
Check the temperatures of the discs. Paying close attention to the rears. They should not be frying pan hot after a run. There is nothing that can't be fixed with a hammer😜😜
11th Jun 2018 7:03pm |
ross161 Member Since: 21 Feb 2017 Location: Birmingham Posts: 12 |
Spot on northernmonkeyjones
11th Jun 2018 7:41pm |
If you can spanner, then I would start by stripping the wheel and calliper off, then removing the pads. Check to see if they come out easy, if so the. It’s probably the calliper, if they are jammed in tight, then unbolt the carrier and clean it with a wire brush and file removing the rust until the pads go in easily. There is nothing that can't be fixed with a hammer😜😜
11th Jun 2018 7:51pm |
