Home > Maintenance & Mods (L322) > Engine replacement - Range Rover 2011 4.4 TDV8 RESCUED |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2308 |
Subscribe to Topix and download either just the 4.4 engine section or better still, download the lot. |
21st Jun 2018 9:52pm |
Salter121 Member Since: 20 Jun 2018 Location: Berkshire Posts: 79 |
Thanks; just subscribed to Topix; very useful. |
22nd Jun 2018 6:10am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3676 |
The TSB with all the details of the turbo drain mod is in the WIKI.
22nd Jun 2018 8:22am |
You might want to look into the oil feed pipe to the turbo’s.
22nd Jun 2018 9:20pm |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 |
Watching with interest 2011 RR Autobiography 4.4 TDV8 |
28th Jun 2018 5:25pm |
The new engine is now being fitting with all the ancillary parts from the old engine and having the sump's swapped as this is an engine intended for an L405.
3rd Jul 2018 6:28pm |
Your braver than me, very interesting project though. 2011 RR Autobiography 4.4 TDV8 |
3rd Jul 2018 6:30pm |
Few images of the old engine
3rd Jul 2018 6:33pm |
Is there any benefit to using an engine from the L405? 2011 RR Autobiography 4.4 TDV8 |
3rd Jul 2018 6:34pm |
They are the same engine to the most part; though the sump is different and all the ancillary set up; but the bare long engine its the identical ford engine baring the sump. |
3rd Jul 2018 6:47pm |
3rd Jul 2018 6:48pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
You're a brave man! Hope it all works out.
3rd Jul 2018 7:23pm |
Had all 8 injectors tested today and 7 need replacing / refurbing . Just looking at the cost of this; is there a real difference between the Land Rover ones and the OEM’s such as AllMake; which seem to be the cheapest - cheaper than refurbish the old ones....I wonder if they have the exact same flow rate. Anyone know? |
4th Jul 2018 7:22pm |
I don’t know if their is anything special about 4.4 tdV8 injectors, but I have had a couple of sets of Td6 injectors refurbished at a Bosch service centre in the past and they were as good as new at a fraction of the cost .
4th Jul 2018 7:44pm |
