Home > Maintenance & Mods (L322) > Second of many questions
Northern lad
Hi All
two questions this time, I have a tow bar attached that I want to remove, is this supposed to be a quick release type? if so how I move the levers in the direction indicated, but it's not budging. second question, there was a recent post about seat / leather restoration, you will see from the photos my seats are in a poor state! the last owner had three boys all into their football, so stud marks every where Big Cry does anyone have an idea whether the seats are repairable / restorable? as they are quite bad (pics of Tow bar and seats below)
 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #483513 15th Jul 2018 5:12pm
Thats not a standard JLR westfalia tow bar sir...
Can you find a makers name?
Post #483519 15th Jul 2018 6:39pm
Paul thornton
It's a brink like mine.
I pushed the lever too hard when I first tried to remove mine and broke it. Luckily spares are available.
You need to get underneath and have a look and you'll see the catch at the back. Loads of wd40 and you'll eventually be able to push it out with a screwdriver.
You'll then need to clean up the removable tow ball / receptacle etc to get it working properly again.
Post #483520 15th Jul 2018 6:54pm
Clivefog
The Leather Doctor sells on ebay - exact colour match and kit will clear that up with minimal effort.
Post #483527 15th Jul 2018 8:55pm
Northern lad
thanks chaps for your replies, I will have a go at the tow bar at the weekend,
CliveFog
would you mind sending a link to the leather doctor on E-bay? I've looked but can only find leather treatment moisturiser etc, not different colours etc.
also a question for everyone were can I find my build sheet? I've looked at Topix with no success
as always any help much appreciated
Steve 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #483611 17th Jul 2018 5:17am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Your interior colour looks the same as mine & is listed as Jet / Charcoal (TCX). Loads of kits on ebay just make sure that you have tinters with it, as I had to add a load of black to match my colour.
Post #483613 17th Jul 2018 8:05am
Paul thornton
Speak to Stacie in the land rover customer relations section on here and she will be able to provide you with a build sheet
Post #483617 17th Jul 2018 8:18am
Northern lad
cheers Paul
I have dropped her a line
Post #483687 18th Jul 2018 5:22am
Northern lad
well had a go at the tow bar, no luck, couldn't see a catch at the back as suggested so tried to undo the bolts only to find the bolt head was starting to turn but no bolt movement so stopped instead of shearing it off!
Highroller my interior is Jet/Charcoal as suggested by the build sheet, still need to find some sort of restoration kit though.
Anyway decided to have a go at the Engine bay it was a bit dirty pics below, probably took about an hour and a half
Post #484327 25th Jul 2018 7:20pm
Highroller
WOW what a difference, what did you use, looks brilliant Thumbs Up
Post #484333 25th Jul 2018 9:24pm
Paul thornton
If I remember tomorrow, I'll get my tow ball out of the boot and show you what I'm on about.
Post #484337 25th Jul 2018 11:14pm
Northern lad
Thanks Highroller
just a bucket of hot water / car shampoo and a sponge, sponge was quite wet, but didn't splash to much water about of course because of the electrics, wiped off the worse dirty drips / smears, then used a damp clean cloth in clean water, it dried pretty quick in the heat last Saturday, then used the famous Back-to-Black with another clean cloth, just need to keep it topped up now, and perhaps get a bit more detailed in some of the harder to reach areas, with something like a toothbrush yes I know what a Banging Head you cant see from the photos but I also did under the bonnet, and the tops of the front wings, on the outside, if you fancy having a go, the seams are quite sharp, and shredded the sponge quite a bit.
Paul in your own time of course, but photos would certainly help, so many thanks for that
regards
Post #484343 26th Jul 2018 5:51am
These guys do specific kits for RR colours, so matching shouldn’t be a problem
https://www.furnitureclinic.co.uk/Colour_Chart?Land_Rover Got - 2017 SDV8 Autobiography in Loire Blue
Post #484354 26th Jul 2018 9:21am
Highroller
Definitely give mine a go next month when I do the oil change. Thumbs Up
Post #484361 26th Jul 2018 10:30am
