Home > Maintenance & Mods (L405) > Check oil level on MY 17 car
Page 1 of 3 123>
AndyS
I'm sure this has been covered before but after checking the manual I can't see how to check oil level, can anyone tell me the procedure?
Post #484554 28th Jul 2018 6:33pm
Baltic Blue
I will show you how to check oil level on a 2011 L322, but please ignore this reply if someone suggests it is different on later model L405’s.
Hope it helps
Post #484562 28th Jul 2018 7:21pm
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
If it is the same as the MY2014 one you need to enter the car and press the start button without your foot on the brake, then press the menu/ok button on the left of the steering wheel, this will bring up the menu in the centre screen between the rev counter and speedo. Use the arrows to scroll down to the service menu and you should be able to check the oil level from there.
 Cheers Ian
Kielder 4x4 Safari
Post #484563 28th Jul 2018 7:27pm
Vogue
It’s extremely simple - and very well explained in the manual - you obviously missed it Wink Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #484565 28th Jul 2018 7:29pm
AndyS
I thought that's the case but I looked in the manual and couldn't find it in the menu selection at the back.
So yes, I'm extremely simple but thanks for the guidance Razz Razz Razz Razz
Post #484572 28th Jul 2018 8:15pm
0949
When attempting to check the oil level in my L322 on the designated service menu page I get 'not available' even when allowing time for it to settle. Any ideas?
Post #484727 30th Jul 2018 2:37pm
Baltic Blue
Open the bonnet,
Then press and hold the cruise control reset button for a few seconds.
The display should reset from “Not available “ to show actual oil level.
Mike.
NB, It only works with the bonnet open. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #484729 30th Jul 2018 2:48pm
0949
Thanks very much Mike. Do I have to keep the menu display open at the time or start again after following your procedure?
Post #484730 30th Jul 2018 2:55pm
Baltic Blue
Leave it reading “Not available”
Then open bonnet,
Then press reset.
It will change to display level.
It is the only way to keep rechecking the level as you are filling up doing an oil change without waiting ages between readings. Thumbs Up G reg 2.5VM Vogue Portofino red 1991- 1999
Post #484731 30th Jul 2018 3:06pm
Baltic Blue
Hold it until display changes.
Post #484733 30th Jul 2018 3:20pm
0949
Worked like a charm! Thanks again Mike.
Post #484747 30th Jul 2018 5:26pm
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
I'm trying to check the oil level on my MY2015 SDV8 but keep getting the 'not available' message. I believe that I have followed all the instructions in the manual, which are pretty much as in this thread. I've tried it with bonnet both closed and open.
Any ideas anyone?
I have a 1,000 mile trip to Gdansk on 18th July so it's pretty important.
Post #560528 7th Jul 2020 6:23pm
DrRob
I’ve heard the sensor sometimes gets damaged by oil ingress to the wiring...sump off job Big Cry
Have you tired checking oil level cold in morning and when hot (20min after shut down for hot reading)? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #560545 7th Jul 2020 8:40pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
I’ve given up trying to work out how to do this, despite following the instructions here and in the online manual (my car came without a manual”because it’s on line now sir”) What’s wrong with a dipstick FFS!
Post #560547 7th Jul 2020 9:02pm
DrRob
Dipstick is too messy for most RR owners Rolling with laughter 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560548 7th Jul 2020 9:03pm
Page 1 of 3 123>
