Home > Maintenance & Mods (L322) > The dredded oil cooler leak !!!
Page 3 of 7 <1234567>
GGDR
Ah ok.
My observation is that the gasket goes between 50 and 80k miles. Yours in that range, just. Confirms my armchair theory anyway!
I've not heard of one going twice.
I like your simple idea of extra silicone.
So maybe a thorough job you won't have to worry about a 2nd time? Hopefully.
Greg Cheers, Greg
Post #484589 29th Jul 2018 9:11am
GraemeS
I'd like to read the TSB beforehand. I found an exploded diagram of the cooler referencing the new gasket and I suspect that the picture was lifted from the TSB. However a revised gasket from that used to assemble the cooler originally should have caused the cooler assy to get a new number which hasn't occurred so perhaps nothing has been done other than to make the gasket purchasable, which implies that the problem will re-occur if nothing else has changed, including where the cooler was replaced with an identical part.
Loctite 518 is for metal to metal face sealing when one or both components are aluminium so the faces might get a smear of that during reassembly and fitting.
Post #484595 29th Jul 2018 10:49am
Baltic Blue
Cheers Greg 🤔🤔 mines on 70,000 but , time will tell.
I fully intend to tackle the job myself when it does start leaking and will be using Hylomar Blue on the joints and gaskets.
I will take my time doing the job, changing the mystery sensor and the O rings at the same time and giving the plenum manifold, etc a really good clean before re- assembling. I am just hoping it gets me through my forthcoming holiday trip without problems.
Post #484598 29th Jul 2018 11:04am
GraemeS
The TSB states that the gasket between the oil filter and the oil cooler fails due to heat damage. Funny that this damage occurs on every 4.4 at around the same age and that LR thought fit to add the repair procedure to the 4.4 in all vehicles in which the 4.4 is fitted. The gaskets are obviously unsuitable.
Post #485134 4th Aug 2018 1:30am
GraemeS
New gaskets now fitted, topped with RTC silicone then left overnight after fitting to cure before subjecting to oil and coolant. The original gaskets weren't protruding and given the deep groove in which they locate, I'm not surprised that they compress only a little then harden allowing them to leak over time. Oil on top of the filter housing indicated that at least the cooler gasket had failed.
Silicone intake hoses 70mm ID x 60mm long were fitted in place of the original early style, re-using the original clamps. 55 mm long would have allowed the intake to readily drop into place instead of being a tight squeeze.
Post #485777 12th Aug 2018 6:27am
GraemeS
Considering that the filter housing / oil cooler gaskets on the 3.6 TDV8 and the 2.7/3.0 TDV6 don't appear to fail yet are located in the same area of the engine, iI suspect that the 4.4's fail because the filter housing sits atop the EGR cooler.
Post #486968 23rd Aug 2018 9:53pm
mpirie
When I did mine, I coated the gasket and clean mating surfaces with a thin film of Blue Hylomar, a non setting sealer.
Of course, making sure none of it got near the coolant or oil galleys.
Mike
Post #486981 24th Aug 2018 8:36am
SinbadRose
OK, so took mine into the local indy to get the squeal and tick noise sorted and asked them to look at the oil leak that arrived the other week Sad (I did the rubber rings myself months ago, so i know its not that)
Been told that its the oil cooler that needs replacing at around £1400. Others are saying around £1k or less on here, so seems very expensive, is it worth putting this to another indy as he said that there is no gasket for it???
How easy is it to get to and replace the gasket. I checked that it had no oil in the coolant so not sure as its the first time i have used them
Post #488829 13th Sep 2018 2:55pm
JCW
United Kingdom 2012 Range Rover Autobiography TDV8 Sumatra Black
Firstly I'd not use the indy you mention, if he's unaware there are infact gaskets (2) for the oil cooler, I'd probably not trust his ability to do the work itself.
I recently changed both gaskets on mine myself (I did have oil in my coolant, although not much as it turned out) the gaskets are cheap, I'd assess the job difficulty as 5/10 for an averagely skilled home mechanic, no special tools and just be methodical.
It depends on whether it is just the gaskets leaking, highly likely, mine were flattened, slighly shrunk and quite brittle (94k miles) or whether the aluminium cooler itself has cracked and needs replacing, unlikely.
Post #488831 13th Sep 2018 3:39pm
nino_nino
SinbadRose,
JCW is correct, it is very unlikely that the cooler itself hase crac and is leaking. get some competent mekanic get this two gaskets from Duckworth Dan and you are set. if I remember correctly gaskets are 15-20 pounds.
Nino Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #488832 13th Sep 2018 4:04pm
SinbadRose
just picked it up. The ticking seems to have gone, needs new belts (screeching noise). May get those done. Just need to find the diagrams regarding the oil cooler location/getting at it. Will take a blast through the wiki as well.
Cheers guys, seems not all Indy are the same, need to find one in the northwest.
Post #488834 13th Sep 2018 4:59pm
JCW
Out of interest, what was their diagnosis / fix for the ticking? (assume you mean engine ticking?)
Post #488836 13th Sep 2018 5:38pm
SinbadRose
It was the idler and the spring had stretched, not ticking anyway. Will sort the screech out with new belts i am told, but defo looking at doing the cooler with someone else
Post #488845 13th Sep 2018 8:35pm
SinbadRose
Anyone got picks etc as a how to do this, will look through more posts, sure i have seen this on one of them.
Post #488852 13th Sep 2018 9:03pm
GraemeS
The indy may have fixed oil cooler leaks before the extra gasket was made available which necessitated the whole assembly be replaced and doesn't know that the intermediate gasket is now available.
Post #488855 13th Sep 2018 9:57pm
