Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
100 degrees is the minimum value I believe Graeme
11th Aug 2018 8:21am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 |
Just checked mine, same fault code and same 100 degree reading as yours. |
11th Aug 2018 10:28am |
Should probably add I thought I’d added a photo of the readings but my IT skills have failed me
11th Aug 2018 10:42am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
temperature on the bank 2 sensor 1 will go above 100 C only if the engine is spinning over 23~25 hundred rpm. in the pic. you can see temp. have gone up so the sensor is working. i have had it. go up ove 280C while the revs are kept up above 23 hundred rpm,s.
11th Aug 2018 11:15am |
Ok cheers cass - was your engine hot?
11th Aug 2018 11:48am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2308 |
In that case that sensor must be the one in the exhaust pipe from the secondary turbo on the left side of the engine.
11th Aug 2018 11:52am |
Euro 4 only has temp sensor in left manifold and oxygen sensor after primary turbo - only measuring EGT in 1 manifold (no need to measure both). Bank1 sensor1?
11th Aug 2018 12:10pm |
So Graeme this shows my 4 EGT readings.
11th Aug 2018 1:03pm |
Nino do you have the error?
11th Aug 2018 1:50pm |
I'm also wondering if Pat @ Gap might know which one is which one...
11th Aug 2018 1:51pm |
Yes it was hot, they all read 100 when it was cold.
11th Aug 2018 2:18pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3676 |
Your I T skills are twice as good than earlier
11th Aug 2018 2:37pm |
I have, it was there first time i checked with IIDTool +/_ 100K km now.
11th Aug 2018 3:46pm |
Nino I think you have disproved part of my theory probably then that sensor reads temp post turbo number two. Which makes sense baciase all readings i've taken are under 2k revs. Cheers, Greg
11th Aug 2018 5:35pm |
