Home > Maintenance & Mods (L322) > Deployable steps
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Deployable steps
Have I missed something regarding the switch location?
Trying to follow some recent posts about a retrofit -- but where does the switch go? especially when you have a sunroof?
Thanks in advance
Post #485918 13th Aug 2018 11:44am
andygts
United Kingdom 2013 Range Rover Autobiography SDV8 Luxor
pop a blank out on the interior light/sunroof panel, insert a peice of plastic trim and then the switch pushes into that.
Pic below might be opposite way round I just pulled it off google.
 Current
2001 Porsche 911 Turbo
_____________________________________
Previous
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #485922 13th Aug 2018 11:57am
opposite side of the sunroof switch...take the blank out ..
edit , as above ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #485924 13th Aug 2018 11:59am
Bushy30
Thanks for the reply Stan -- I should have said -- I have a microphone fitted the other side of the sunroof switch -- well at least I think I do -- I haven't actually removed it to check that's where the microphone is!!!
Sorry don't have a picture at the moment!
Post #485925 13th Aug 2018 12:02pm
Bushy30
Anyone have any thoughts?
Post #486057 14th Aug 2018 11:03am
yes , check that panel... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #486062 14th Aug 2018 12:48pm
Bushy30
Ah Stan, your insight knows no bounds -- yes of course I should -- will investigate and report back Smile
Post #486068 14th Aug 2018 1:20pm
Redtail
On my panel the microphone is fitted between the sun roof switch and blank on the other side of the little sub panel. The slots in this little panel between the switches are for the microphone. The blank switch on mine had slots in it but nothing fitted behind it. If you take the whole panel out, 2 screws inside the sunglasses cubby hole, all should be revealed.
Roy
Post #486073 14th Aug 2018 1:51pm
Bushy30
Roy,
Thanks for that, and indeed it would explain what I'm looking at on the panel
Ian
Post #486088 14th Aug 2018 3:33pm
Bushy30
Just an update on this for anyone looking later: -
Microphone position on 2004 plate was in the black grilled switch cover on the right side of the front light console.
The same switch cover exists in my 2011 plate -- but the microphone has moved! indeed it is now behind another grille in the centre of the same overall cover!! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #488394 8th Sep 2018 12:28pm
