Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2311 |
I've spotted a distinct difference between the pipes shown in diagrams/pictures and my April 12 build's pipe in that mine has a join between the flexible section and the rest of pipe that continues to the turbos. I can't currently loosen the bolt but once I have an appropriate tool, the end section of the pipe will be removed to allow the o-rings to be fitted whilst away from the back of the engine. |
9th Jul 2018 7:30am |
Some measurements from mine's later version 2-piece pipe:
10th Jul 2018 3:40am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
where is that pipe from exactly Graeme?
10th Jul 2018 7:06am |
Its at the top end of what was originally a single pipe. I suspect the 2-section pipe was developed so that it could be guaranteed that the fitting into the block could be under no stress. I rejoined mine after tightening the spigot in the block.
10th Jul 2018 8:14am |
RiDDO Member Since: 13 Nov 2015 Location: Lincolnshire Posts: 33 |
My 2012 TDV8 is currently at Duckworth's in Market Rasen having a new oil cooler, alternator & n/s rear light cluster. I've been smelling hot oil for almost a year, last Sunday afternoon smoke started coming from under the bonnet. Note to self in future check for this stuff on Full Fat! --RiDDO |
8th Aug 2018 1:35pm |
Ian S Member Since: 01 Sep 2018 Location: Fufe Posts: 1 |
Hi all I’ve just found oil leak on my tdv8 I’m going to check it tomorrow |
1st Sep 2018 10:41pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4231 |
"First, remove the air box that houses the pollen filter, 2x 13mm headed nuts then pull the whole assembly off. "
19th Sep 2018 12:21pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3677 |
Picture with airbox removed. (2x 13mm nuts to remove. 30second job.)
19th Sep 2018 12:41pm |
Cheers. I was after the location of the nuts - or is it pretty obvious 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
19th Sep 2018 12:44pm |
19th Sep 2018 2:12pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
19th Sep 2018 2:14pm |
Thanks. Helps heaps. Will be having a gander over next few days under there when I collect my 2011...
Take a good look at this hose joint whilst you have the bonnet up.
19th Sep 2018 2:20pm |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 144 |
That fitting failed on my car,fortunatly under MP.Nino_Nino has posted the fix and yes it is easy!! 2012 TDV8 Vogue SE 4.4 |
22nd Sep 2018 12:01pm |
