Home > Technical (L322) > 8 speed gearbox oil flush recommendations and advice please
Page 3 of 4 <1234>
Just thought I’d pop on that I’ve also just the gearbox overheating message.... what quantities do we need to do a fluid drop and pan change? 5 litres? There is nothing that can't be fixed with a hammer😜😜
Post #492039 12th Oct 2018 10:35pm
cass
United Kingdom 2014 Range Rover Autobiography SDV8 Causeway Grey
I’ve done mine twice and it took almost 5 litres each time, others have reported as little as 3 litres - I ordered my fluid from mytyres.net genuine fluid for about half price
Post #492041 12th Oct 2018 11:27pm
Yes just had a look mytyres.co.uk has LG8 for about £19 a tub.
https://www.mytyres.co.uk/cgi-bin/oshop.pl...disabled=1 There is nothing that can't be fixed with a hammer😜😜
Post #492058 13th Oct 2018 8:44am
GGDR
Opie's price is £29.95 per one litre. So great tip on the mytyres Thumbs Up
I'll be doing mine soon so thanks!
Is mytyres one of the those .co.uk site that is really in Germany?
No problem for me I got my Helix engine oil from a German site and it cost loads less.
. Cheers, Greg
Post #492060 13th Oct 2018 8:52am
I just sent the price to opie to match....... see what they do.
Anyone got any tips on what to use in place of the special tool. I am going to have a look at it later and see if there is anything in my box which will do it. Failing that it’s a trip to the cheap tool shop to get a budget set so I can cut down an Allen key There is nothing that can't be fixed with a hammer😜😜
Post #492061 13th Oct 2018 8:57am
GGDR
Not sure about the tool but I read you don't need the special tool.
Counter of beans posted this:
http://www.fullfatrr.com/forum/post475059.html
all seems pretty straightforward. A ramp would be good for this job though.
. Cheers, Greg
Post #492063 13th Oct 2018 9:24am
Baltic Blue
I noticed when I had mine done they used an Allen key socket in a standard ratchet, something like this example, but sorry I didn’t see what size it was.
Post #492064 13th Oct 2018 9:29am
m@ttsFF
United Kingdom 2016 Range Rover Vogue SE SDV8 Corris Grey
There are 10l of zf8 on eBay for 169 quid delivered .. 4.4 AdBlu Tractor
4.2 SC - sold
Post #492220 14th Oct 2018 12:36pm
That’s cheap.
I’ve just ordered some from Mytyres.co.uk as opie couldn’t get to their price. Which is fair enough.
So I’ve managed to get all the bits for:
£112 - 6 litres of zf8, hope I don’t need more, I shouldn’t reading all the posts about it.
£65 - ZF pan filter (hoping it’s right but I did get the PN off ZF)
Total £177 Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #492450 15th Oct 2018 7:58pm
Oil has arrived this morning.
At the price above.
6 litres of ZF 8🤗 looks genuine and I’ve no reason to doubt that it is. There is nothing that can't be fixed with a hammer😜😜
Post #492895 19th Oct 2018 11:23am
RickR
England 2010 Range Rover Vogue TDV8 Galway Green
Evening all, I can recommend JAS Land Rovers at Pocklington nr York for any Landy/Rangy work inc. 8sp gearbox`s. Phone no. 01759 487500 or look them up on F##ebook.
Post #492933 19th Oct 2018 6:32pm
nino_nino
no special tool needed northernmonkeyjones.
Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #492945 19th Oct 2018 7:37pm
Waiting for the pan to arrive now, which DPD have just told me is coming on Monday.... There is nothing that can't be fixed with a hammer😜😜
Post #492960 19th Oct 2018 9:34pm
gg2201
Its a 10mm allen head its only tightened to 8nm and is a plastic drain plug
Guide here on how to do it
https://www.zf.com/global/media/medien_mas...130_EN.pdf
The bf replaced the pan and oil in mine and only got 3.5 litres out roughly. About 1500 miles later we started to experience torque converter judder at around 30 mph with very light acceleration but a full £300 flush with one of those machines at our local LR Indy sorted it out.
The changes are now rediculously smooth and we also did the transfer box/diff oils at the same time. 2011 4.4 TDV8 Autobiography
Post #493057 20th Oct 2018 9:26pm
Pan has arrived.
Until I get under I won’t know if it’s right, but it’s a ZF one made by guess who....
Yes. Filtran. There is nothing that can't be fixed with a hammer😜😜
Post #493234 22nd Oct 2018 12:30pm
Page 3 of 4 <1234>
