Home > Technical (L322) > Battery AGM or not
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Battery AGM or not
My 2010 3.6TDV8 has an AGM battery that is not very healthy. I thought AGMs were only used with stop/start technology which mine does not have.
I have a brand new unused Bosch type 020 battery that I bought for my old vehicle but never fitted so could I use this to replace the existing AGM battery as it is a higher power rating or are there other differences.
Keith
Post #492510 16th Oct 2018 11:48am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Keith,
I went for a non AGM on my 4.4 TDV8 -- mainly because Halfords recommended the battery for my vehicle and it comes with a 5 year waranty -- however others here have pointed out that this *might* not be a crash hot idea -- so I'm in a testing phase, the battery has only been fitted for a week or so.
But here's the not so good news for you -- if your battery compartment has all the same gubbins in it as mine the 020 won't fit -- I know, I tried an 020 first, it had a larger capacity than the 019 I have fitted, and was £7 cheaper, winner all round I thought, but what with the drain pipe from the scuttle panel, and the very large +ve terminal connector there isn't enough room for it Sad
Hope that helps
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #492517 16th Oct 2018 12:16pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I have an 020 in my 2011 , its very tight and i trimmed off a bit of the bottom plastic on the battery ro facilitate the fitting. The 2011 uses an AGM normally because the alternator is ' intelligent ' and varies the charge. It keeps the battery at 80% and so it may not be suitable for a normal battery. All of my info is from the net and im far from an expert. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #492541 16th Oct 2018 2:53pm
drakes
Thanks for the replies. Have been reading what I can I am not certain mine should have an AGM anyway.
Can anybody with a 2010 3.6 TDV8 confirm what sort of battery they have.
Keith
Post #492550 16th Oct 2018 3:38pm
Bushy30
Dolph,
How on earth did you get it in? -- at the right hand end is the scuttle drain pipe, and then at the left hand end is a huge +ve terminal block connector -- I get it goes in front to back, but left to right was a nightmare!
Previous: -
Post #492574 16th Oct 2018 6:28pm
dolph34
Hi , i had one in my 2007 as well, im sure others have fitted 020s in theirs too. It is tight but a bit of trimming amd robert is your dads brother Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #492604 16th Oct 2018 9:36pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
I ran an odyssey pc1500 in my 2010 3.6 for two years no problem. Cheers
James
Post #492613 16th Oct 2018 10:18pm
Keith, your 2010 had a mod done by JLR to the charging system and at that point they changed the batteries to AGM... I believe with the Mod you would need to run an AGM sir... Thumbs Up
Post #492617 16th Oct 2018 11:22pm
drakes
Craig
Thanks for that, I also pm'd Dan at Duckworths and he sort of confirmed the same thing.
As mine is a 3.6 I don't have the ecu in the way so I am going to see if the 020 that I have will physically fit and the decide which AGM to buy as there does seem to be some debate as to the possibility of fitting the 020 in the later vehicles.
Keith
Post #492630 17th Oct 2018 7:20am
