Home > Technical (L322) > 2012 tow bar
philip600
2012 tow bar
Hi, I want to try & get a tow bar for my 2012 Westy, it's not something we 'need' as such but more for just in case or to use for a bike rack so I don't want to spend a fortune fitting one. I've been looking for a second hand one on the usual online auctions but although there are quite a few listed that fit the earlier models there's never many listed for 2010 - 2012 models so my question is what is different between the one I need & the earlier ones ? My car has the westfalia brackets / towing eye so would the earlier cross bar fir to these or not ? Also the plug in electrics, are the kits for earlier cars different ?
TIA
Phil
Post #493010 20th Oct 2018 4:01pm
DrRob
I’ve learnt from Craig on here that electrics from 09 onwards are different to earlier ones. No module just plug it in Thumbs Up PF Jones do them or Dan at Duckworths for Genuine with some forum discount Thumbs Up
http://www.fullfatrr.com/forum/topic23827.html Thumbs Up
It might also need hooking up to a diagnostic to tell the car it hasn’t towing electrics fitted now Thumbs Up
No idea on tow bars Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90
Post #493014 20th Oct 2018 4:46pm
rjff
Hi Phil
On the P F Jones website they have a lot of info you can browse and make a decision on what you require. I'm not recommending them, didn't buy from them and you will have to assess their customer service and check prices elsewhere. This info should, I hope, assist in buying used if you so decide. Prices new may make you take a deep breath!!
Westphalia bars are listed as under 02-09 and then 09-13 for Fullfats. The diagrams do not appear to show any differences, but I suggest there may be, knowing how manufacturers like to alter things. I don't think the Westphalia bar has a simple bolt on cross piece, it appears welded in. Thus you would have to replace the brackets with a complete unit. Westphalia are I believe original fitment.
Witter appear to do a bar which seems a lot cheaper, but check what comes with it.
Also, I don't think gooseneck fittings will support a cycle rack. Westphalia have a flange fitting which may do the job for you. None of these new are cheap, and if you buy secondhand, make sure it is EC marked.
Your car build sheet should inform if the electrics are tow prepared and as DrRob says they plug in to a socket in the left hand rear of the spare wheel well.
Info links
https://www.pfjones.co.uk/tow-bars/towbars...rs-en.html
https://www.pfjones.co.uk/tow-bars/towbars...wbars.html
https://www.pfjones.co.uk/landrover-range-...w-bar.html
https://www.pfjones.co.uk/range-rover-towb...-only.html
https://www.pfjones.co.uk/landrover-range-...-only.html
Hope this helps. Cheers
Richard
Gap IIDBT
Post #493015 20th Oct 2018 4:51pm
As above the brackets your car has come off and go in the bin. They are replaced by the tow bar.
The westfalia tow Bar comes in two parts
The main frame
The bar bit
For originality I would go with a westfalia and a removable farmers flange bar. This slips in and out of a square hole in the main frame leaving a neat appearance when removed.
There are cheaper but they tend to be a bit clunky looking in comparison.... There is nothing that can't be fixed with a hammer😜😜
Post #493047 20th Oct 2018 8:10pm
gg2201
We went for a tow-trust detachable on our 2011 Autobiography. We had it fitted locally and was £515 fitted which was is a lot cheaper then what they list it on their site for!
https://www.tow-trust.co.uk/towbars/landro...002+-+2012
Pic of ours fitted its very sturdy and a doddle to detach the swan neck etc...
 2011 4.4 TDV8 Autobiography
Post #493053 20th Oct 2018 9:06pm
philip600
Hi, thanks for taking time to reply everyone, much appreciated Thumbs Up
Plenty of info to look into, I did wonder about the suitability of the swan neck type if I wanted to use my cycle carrier so will check on that too. Seems crazy to have the westfalia brackets on the car but can't just buy the crossbar though Sad
Will have a good look through the links, thanks again.
Cheers, Phil
Post #493092 21st Oct 2018 9:51am
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
PF jones for Westfalia one , wiring is plug n play , put one on for a customer a few weeks ago and easy DIY job .
Post #493682 26th Oct 2018 2:40pm
