Home > Technical (L322) > SIDE (WING) INDICATOR NOT WORKING - fixed! |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
You could try disconnecting the -ve terminal on the battery and leaving it disconnected for five minutes and then reconnect it. You might be lucky ( or not ).
20th Oct 2018 6:52pm |
Zain Member Since: 17 Apr 2014 Location: London Posts: 98 |
Disconnected both terminal leads on the battery in order to recharge on a CTEK charger - still no joy with the side indicator.
20th Oct 2018 8:15pm |
UPDATE 1
22nd Oct 2018 10:46pm |
You could try taking the side repeater off the car and connecting it directly to the battery and see if it does in fact light up. |
23rd Oct 2018 10:45am |
I swapped the drivers side repeater (bulb connector+bulb) over to the passengers side and it works.
23rd Oct 2018 1:01pm |
If you have 12V and earth at the repeater you would expect the repeater bulb to be lit up all the time, something I don't understand. |
23rd Oct 2018 2:56pm |
Not sure i understand 100% too but i faintly remember (from somewhere) that voltage can exist without current flow (but not the other way around). I have a very very basic school boy understanding of electronics so may be some one with more authority on the subject matter can comment. |
23rd Oct 2018 6:01pm |
If you have 12V and earth the bulb should be alight.
23rd Oct 2018 6:20pm |
Nope....a standard filament bulb is fitted (which definitely works as tested on the passenger side indicator) |
23rd Oct 2018 8:35pm |
Have you checked the earth at the repeater connector to an earth point on the car? If not I would. |
23rd Oct 2018 9:08pm |
No, didnt even occur for me to do so. The LCM is sitting on the table so once ive connected it back up i'll give it a go.
23rd Oct 2018 9:24pm |
You need to connect a multimeter to the repeater connector earth terminal to and earth point. The easiest earth point to find is probably in the engine compartment. Any of the bolts/ nuts on the top of the air suspension struts will be ok. |
23rd Oct 2018 9:38pm |
MOT is due soon so ive decided to send the LCM off for repair to an auto electrician who offers LCM/BCM repairs on ebay.
25th Oct 2018 12:35pm |
FIXED!
28th Oct 2018 5:51pm |
