Home > Technical (L322) > T91R remote. |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
From what I can tell, and it's a bit of a mystery, the fob you need should have 'on' and 'off' so I think you have the wrong one Current: 2011 FFRR Vogue SE 4.4 TDV8
12th Nov 2018 10:44am |
Simon123 Member Since: 02 Jan 2018 Location: Pembrokeshire Posts: 32 |
Only ones I can find with an on and off button are specifically for the 405 !! Am really confused !!!!! |
12th Nov 2018 10:55am |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 120 |
This is the one you need...
12th Nov 2018 11:10am |
Thanks for that. Any ideas where I can get one or point me to a link |
12th Nov 2018 12:41pm |
I got mine from ebay a couple of years ago. I've had a quick look and can't see any on there at the moment unfortunately. Not sure where else you might get one other than a main dealer I'm afraid. 2011 4.4 TDV8 Vogue SE
12th Nov 2018 1:09pm |
OOh just spotted this...
12th Nov 2018 1:11pm |
Ok , thanks for that |
Unfortunately looks the same as I've got !! No switch marked on instead heater/ fan sign. Was told these were not compatible |
12th Nov 2018 1:15pm |
Or this cheaper one. They look the same as mine but the on button has a different picture
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1461 |
I got one from there but cant get it to work #8o( BMW i3 Electric Car
12th Nov 2018 1:16pm |
Is the battery good on your one? What happens when you try to sync it to the T91? 2011 4.4 TDV8 Vogue SE
12th Nov 2018 1:17pm |
Have changed the battery for a new one but just flashes 8 times, on or off. The transmitter in vehicle is marked T91R |
12th Nov 2018 1:23pm |
Did you keep the on button pressed as you connected the power back on the T91R receiver? 2011 4.4 TDV8 Vogue SE
12th Nov 2018 1:39pm |
No, pressed the off button, was that wrong ?? |
12th Nov 2018 1:42pm |
