Home > Maintenance & Mods (L405) > L405 SDV8 oil leak help needed
Page 3 of 3 <123
Baltic Blue
The engine is designed for top down maintenance, and is fitted with an oil extraction tube.
Post #495399 12th Nov 2018 7:20pm
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
Well... every day is a school day Razz thank you for sharing
Post #495400 12th Nov 2018 7:28pm
Baltic Blue
From the workshop Manual for the same engine in an L322.
Post #495401 12th Nov 2018 7:32pm
GraemeS
Saab instituted oil extraction from the top for a few years then found sludge build-up caused engine failure so reverted to sump draining. Perhaps oils have improved since that time to avoid sludge build-up but I'll never risk my engine by taking the short-cut.
Post #495409 12th Nov 2018 8:51pm
swissomatic
United States 2015 Range Rover 5.0 SC V8 Fuji White
Interestingly Caterpillar diesels in mining trucks were available for a while with oil replenishment systems. Concept was that they fed a very small amount of oil through the injection system and burnt it slowly so that all that was needed was the addition of oil to top off when needed. Saved service time, did away with oil disposal requirement, saved liability of oil drainage in workshops etc and consequent loose plugs and forgotten refills etc. larger sumps and remote reservoirs provided reserve capacity. Big benefit was that oil quality on average was better as it never degraded to the end of oil change interval when additives were depleted.
Interestingly it was discontinued I think because of potential emissions related issues.
Bit off topic but might have protected you from the dreaded “ finger” problem which caused your issue in the first place.
Post #495443 13th Nov 2018 3:40am
Charles89
Hi everyone,
Quick update, it's still smoking, but doesn't appear to be loosing any oil (at least not on the dipstick) I have however now developed a flat (won't start) battery every morning and evening when I finish work! I will have to ask in another post about that one.
I will keep driving the car daily in the hope the smoke will stop soon when everything is burnt off
Post #495599 15th Nov 2018 8:34am
mpirie
Great news Charles. Thumbs Up
Mike
Post #495602 15th Nov 2018 8:55am
I can't believe they dropped the sump bung in a JLR main dealers! Are you quite sure you were not watching him do something else sir? JLR dealers all service cars to the manufacturers specs and a 4.4TDV8 is definitely a suck oil out engine as per JLR Topix...
I certainly wouldn't be doing any of this stuff myself if id just paid to have it serviced sir... Whistle Its down to the dealer that made a mistake with the oil seal on the filter housing to A, clean up the mess... B, reimburse you for your out of pocket expenses (oil etc etc etc) and C, to make sure your 100% happy with the job you have just paid ALOT of money to have done!
One last point to make... What oil have you used to top up with? Was it 100% the correct grade/coded oil for the DPF? Where and what did you buy? i ask as your oil type/grade is critical and will not mix properly with a generic 5/30 5/40 10/30 etc etc diesel motor oil off the shelf in a service station for example... The oil needs to meet a code criteria (I don't have that info here right now to hand) which is in your service book... If, your not 100% sure! You need to go back and tell them. Its their issue to put right Thumbs Up
Post #495619 15th Nov 2018 10:35am
Charles89
It's booked in today at a main dealer. So I will update you later.
Absolutely, sump plug was removed and oil drained from below. I asked on the phone about sucking oil out and the service manager said that only applys to the first 4 services, after 4 services or 80k miles they drain from the sump. Hence the different service specs in the book for given millages.
As for oil I bought some from the same dealer, it was shel helix ultra 5w 30 genuine oil. I am defiantly going to give them some stick Thumbs Up
Post #495698 16th Nov 2018 7:10am
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Cam-Tech-Craig wrote:
One last point to make... What oil have you used to top up with? Was it 100% the correct grade/coded oil for the DPF? Where and what did you buy? i ask as your oil type/grade is critical and will not mix properly with a generic 5/30 5/40 10/30 etc etc diesel motor oil off the shelf in a service station for example... The oil needs to meet a code criteria (I don't have that info here right now to hand) :
5w/30
AF-L
WSS-M2C934-B
Post #495712 16th Nov 2018 12:26pm
Charles89
Quick update. No more leaks and oil level is fine. Looks like the inner V was full of oil from the oil seal breaking and has finally burnt off.
Post #497294 2nd Dec 2018 9:03am
Page 3 of 3 <123
