Home > Technical (L405) > Deplorable side steps paint peeling off
Has633
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
The paint was peeling off and under warranty they replaced with new side steps.
The new side steps are metal but top layer is rubber coated and bottom part of side step has plastic cover.
Looks much better.
Dealer mentioned there is techinical bulletin on side steps.any one have same problem should contact and most likely they will replace. My vehicle is under warranty till jan 2019
Post #483398 13th Jul 2018 9:32pm
p38arover
Australia 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I'd find it deplorable if the paint was peeling off them, too. Smile Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #483403 13th Jul 2018 11:56pm
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
I have black metal ones with the same issue and today I will be painting them up again to look fresh, they are all scratched. I will take pictures of the restoration
Post #495782 17th Nov 2018 10:00am
p38arover
No longer deplorable! Mr. Green Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #495783 17th Nov 2018 10:14am
Charles89
As promised this is some before shots.. and after Cool
I used some scotch bright on the aluminium, and a sanding block on the board, 3 coats later and there she is... the nice thing is it's now 100 anti slip as it's textured rather like grip tape on a skate board ( if kids still use that stuff in our days anyway! )
Thought I would share Smile
Post #495844 17th Nov 2018 10:37pm
[a bit late] but thats a good job... Thumbs Up
Post #506201 24th Feb 2019 3:54pm
vanquishspirit
Unnecessary quote removed
That looks a great job, thanks for posting that. I am just about to do mine as they are flaking. Broke the rule of a lifetime and took it to the local car wash. Their uber powerful jet wash power stripped the paint on the side of my steps. Looks awful from the side now. Not sure is it powder coated? Anyway, I was wondering whether you took yours all the way down to bare metal or feathered the stripped edges and went from there? Did you paint the side of the steps as well as the top surface? 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
1972 Suffix A fully restored 2 door
1970, chassis number 26 the first of the press launch cars, Masai Red
2013 4.4SDV8 Autobiograpahy
Post #506205 24th Feb 2019 4:21pm
Charles89
I painted it all, sides included. No bare metal. I just lightly sanded
Post #506207 24th Feb 2019 4:27pm
stillnotpc
Nice job! Mine has a similar problem, and I had figured out that this should be a good solution, but great to have that confirmed. Philip in Oxford
Now on my seventh RR (while not quite bringing myself to sell no 6...)
Post #507099 3rd Mar 2019 9:54am
