Home > Technical (L405) > Windows fogging up from the inside |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34925 |
you have moisture in there somewhere...could be wet coats , a leak by a door etc or the AC is leaking ..
13th Dec 2018 12:51pm |
Kace Member Since: 08 Sep 2018 Location: London Posts: 13 |
Thanks.
13th Dec 2018 1:20pm |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 891 |
Unnecessary quote removed
13th Dec 2018 1:23pm |
the side windows do not demist, they are antennas.. |
13th Dec 2018 1:53pm |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1165 |
Is the setting that allows air in from outside on or recirculating? Allowing outside air in may help.
13th Dec 2018 3:16pm |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 |
i remember steaming up the windows of my old Mazda 323 back in 1982........ Current: FF Westminster money pit
13th Dec 2018 3:21pm |
The air recircle is not in. |
13th Dec 2018 3:28pm |
wrong forum bradders |
13th Dec 2018 3:36pm |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1071 |
It is also worth cleaning the inside of the windows with something rough as they build up a residue of gunge, in the good old days I use to use fine wire wool with window cleaner, now I use magic ceramic sponge with window cleaner and then a micro fibre cloth. letters not necessarily in the right order |
13th Dec 2018 3:47pm |
Any suggestions, Stan ? Current: FF Westminster money pit Gone: RRS 4.2 SC RRS 3.6 TDV8 FL2 TD4 |
13th Dec 2018 3:54pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
Check your pollen filter in the front isn't clogged up and restricting air throughput. |
13th Dec 2018 3:56pm |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
too many folk breathing inside - tell them to stop immediately! |
15th Dec 2018 12:29pm |
Has your windscreen been replaced (is it genuine LR)? |
15th Dec 2018 1:32pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
Think that’s normal to some extent, if it’s damp. You get inside with wet clothes etc and it all goes to make the car steam up.
15th Dec 2018 1:54pm |
