Home > Maintenance & Mods (L322) > Massive creaking...
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Massive creaking...
You know that massive creaking noise you get from the rear when the top suspension bushes have gone , sounds like an old cart on leaf springs... well I'm getting it from the front !
Any ideas people ?
Post #498490 13th Dec 2018 8:20pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Could be the ball joints on the front lower suspension arms. When they get worn they can make a creaking noise 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #498505 13th Dec 2018 9:47pm
DaveK
Just replaced the kink shaped arm , the one with the seperate ball joints, on both sides. Couldnt find any play in the other ones but its difficult to get enough force on them to spot play unless they are really knackered. They also have a large bush. Looks like thats the next step...
Post #498506 13th Dec 2018 9:57pm
fisha
Its most likely the ball joints, and less likely the arms ... mine is doing exactly the same at the moment ... a very short term fix as per below ...
I punched a hole in the rubber with a small screwdriver and shoved an mtb grease gun in there and packed it with grease. The creaking didn't go until it was driven. I think the bumps of the road allow the ball joint to move in a way which that just turning from side to side doesn't.
Emphasis on the short term fix though ... I'll be ordering a few parts shortly to replace both ball joints, which I'll film as well.
Note: Do not expect dealer dollar work mind in the video ... think more like driveway dollar !!! .. It'll be a bit tongue-n-cheek. V8 or else ...
Post #498528 14th Dec 2018 1:46am
DaveK
That is it ! The two ball joints that are screwed in to the hub have just been replaced so it must be the ones in the lower arms. Many thanks for this
Post #498543 14th Dec 2018 9:46am
paul70
Definitely ball joints I'd say, had both sides replaced this year the noise was awful. Only thing I'd have done in hindsight was have both done at the same time and i'd have saved the cost of tracking as it would have only needed doing once. The part wasn't expensive relative to the labour and tracking doing.
Post #498548 14th Dec 2018 10:06am
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Unnecessary quote removed
Great video Thumbs Up
Post #498613 14th Dec 2018 6:40pm
DaveK
Posted whilst holding a large tree but the replacement of the lower ball joints seem to have done the trick. Just front tracking to be checked now but the £70,000 hunters wheel alignment set up at my local kiwi fit is boogered !!
Post #499313 21st Dec 2018 11:06am
