Home > Technical (L322) > Another non starting issue m62 v8 - resolved! |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
Have you tried jump starting her ? They seem to be a bit fiddly if battery is not full .Even if it is reading full I would try that first . Good luck. |
16th Dec 2018 12:20am |
Zain Member Since: 17 Apr 2014 Location: London Posts: 98 |
nope not yet...tis pitch black outside.
16th Dec 2018 12:32am |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
If you can smell burning or a shorted wire in the engine bay check your thermostat wiring.
16th Dec 2018 12:38am |
This thread http://www.fullfatrr.com/forum/topic47537.html
16th Dec 2018 1:16am |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
I wouldn’t assume that the battery is ok just because you are seeing healthy voltage. The fact that trip distance and time reset in cranking suggests that voltage is dropping to a very low level in cranking. Just reading the voltage of the battery at rest wont tell you much if there is a dud cell on the battery. You need to test it under load, which is best done by somewhere with a battery load tester. I believe AA, RAC etc often carry them in their vans.
16th Dec 2018 10:39am |
The following circuit diagram might help. There are essentially three possibilities:
16th Dec 2018 11:06am |
Many thanks for the detailed replies - very informative.
16th Dec 2018 11:08pm |
annette Member Since: 07 Nov 2018 Location: Tilarán Posts: 30 |
Do you get B+ coming in and out of R102 (starter relay)?
18th Dec 2018 2:19pm |
UPDATE:
18th Dec 2018 7:02pm |
Good glad it was simple .Now to save yourself a bit of grief get yourself a jump start pack and carry it with you .Xmas is coming 👍 |
18th Dec 2018 8:43pm |
