Home > Maintenance & Mods (L322) > flat battery |
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 |
This is the one I went for and certainly is same size and same CCA rating as what was fitted, which I believe to be the original as it was Land Rover branded one (made by Varta). No problems so far.
18th Dec 2018 8:00pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3688 |
Dr Rob,
18th Dec 2018 10:03pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
I got into a debate on a fb group about this, I suspect the stop/start mentioned in various battery suppliers' listings refers to the push button start (ie final facelift) models since as far as I know no L322 had the stop/start function. 2010 4.4 TDV8 Vogue SE |
19th Dec 2018 9:07am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Cheers chaps! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
19th Dec 2018 1:12pm |
Early 4.4tdv8’s were not supplied with AGM batteries, but were recalled for all of them to be changed out for AGM types because the originals were not up to the job.
19th Dec 2018 1:21pm |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 326 |
Digging up an old thread, but it's probably one a lot of people use as reference so it's perhaps worth adding too.
9th Dec 2020 12:04pm |
That sounds pretty consistent with what I’ve seen, yup.
9th Dec 2020 3:19pm |
