Home > Technical (L322) > locked out |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Battery in key fob ? .
20th Dec 2018 2:00pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3685 |
Tip of the day... Duracell batteries work best in key fobs.
20th Dec 2018 3:41pm |
Nice but dim tim Member Since: 28 Feb 2018 Location: Fareham Posts: 5 |
Key fob battery changed twice ? |
20th Dec 2018 5:17pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
First post and you want to know how to get into a locked FFRR, hmmmmmmm. |
20th Dec 2018 5:19pm |
Without a key or a lock that won't work, it is nigh on impossible without causing some serious damage to a door or breaking glass. ( I know I tried when I locked my keys in the car) Had to buy a new key (my lock worked OK)
20th Dec 2018 6:06pm |
Cheers joe I think you may be right about smashing the drivers window . I was thinking about getting the bonnet and disconnecting the battery ?, would that reboot the cars system and let my in to my car |
20th Dec 2018 7:36pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7639 |
Take it you have tried holding the unlock button down on the fob to see if all the windows come down? You get the red light on the key when you press the button?
20th Dec 2018 8:09pm |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
How can you tell battery is fully charged ?Mine did that when I left side lights on all night had to jack car up and connect battery pack to starter motor connection then she unlocked no prob .My key would also not unlock drivers door at the time so I fixed it so I would not get caught again good luck |
20th Dec 2018 9:23pm |
Cheers mjdronfield and rik, just had a go at press and hold unlock button, no joy will have a go at starter motor tomorrow cheers lads. |
20th Dec 2018 9:47pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
How did you charge the battery via the towing connection as that should be connected to an ECU
21st Dec 2018 3:03am |
^ There are two direct feeds from the battery, albeit through fuses, to the rear tow sockets which can be used to charge the battery. These two don't go through an ecu. |
21st Dec 2018 7:05am |
Every day is a school day |
21st Dec 2018 9:16am |
GraemeJudge Member Since: 10 Feb 2018 Location: Fareham Posts: 50 |
I have also put an Anderson connector to the jump start point and mounted it on the front bumper on with a cover allowing me to put a multi meter across and check the voltage of the battery and make it nice and easy to jump start if needed,
21st Dec 2018 9:21am |
The forum offers a made up CTek charger connector to the trailer socket.... (see Shop)
21st Dec 2018 9:42am |
