Home > Maintenance & Mods (L322) > Replace Suspension Arm Bushes - What Do You Think? |
srpara Member Since: 03 Oct 2013 Location: moray Posts: 115 |
If the joint has gone on the bottom arm then you will need to replace that whole arm, the other swivel joint is a separate item so you would not have to replace the arm with the big bush in it that connects to it. |
15th Oct 2018 6:11pm |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
I think - and hope - it's just the bush that's gone.
16th Oct 2018 8:43am |
Is this dealer dishonesty or incompetence?
29th Oct 2018 4:09pm |
Both more than likely |
31st Oct 2018 12:25am |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 |
How do you rate the Bearmach suspension parts? any issues fitting etc? 2011 RR Autobiography 4.4 TDV8 |
3rd Jan 2019 5:25pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 785 |
About to replace the top rear bushes on both sides which have started the creaking pram noise at 110,000 and which appear to be the original ones. Finding new replacement concentric bolts, washers and nuts is proving a problem though. |
3rd Jan 2019 8:14pm |
is that for the rear?
3rd Jan 2019 8:23pm |
Yes, the bolt, nut and washer that is used for the top bush that also adjusts the rear camber. Looks like you have the lot but how come a bolt comes in at £14.00 ! |
3rd Jan 2019 8:27pm |
Listed on Advance Factors
3rd Jan 2019 8:32pm |
