Home > Technical (L322) > I did not know that. Rear Wiper - two speed settings.
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Do me a favour -- stop, please, I have to keep dashing downstairs from the office and out to the car to try these things Rolling with laughter Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #509319 20th Mar 2019 3:11pm
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
When you turn your headlights on (2007) the headlights move around in all angles. Only noticed when I got someone to start the car to test the new headlight bulbs I was putting in.
Post #509320 20th Mar 2019 3:14pm
^ only adaptive headlights do that..
Post #509321 20th Mar 2019 3:15pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Full Fattie wrote:
What happens if you do both
As its a Range Rover it'll most likely go into 'crap itself mode'!!
Post #509328 20th Mar 2019 3:28pm
Full Fattie
Any others?
Post #509332 20th Mar 2019 4:06pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
The only issue with the twin visors is the clip tensds to break as soon as you use it Censored & at circa £35 a pop I stopped using mine after replacing it in 2 years!!! 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #509341 20th Mar 2019 5:38pm
mjdronfield
My 1988 7 series had the thing just the same with the intermittent wipers....turn them on and off, and it times till you put them on again. That is then the intermittent wipe gap set.
No really needed if you have rain sensing wipers, but they obviously kept it for the rear wipe.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #509355 20th Mar 2019 6:54pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Youngest daughter had a R plate little Skoda years ago and it did the on/off set the rear wiper intermittent thing.
Post #509372 20th Mar 2019 9:30pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Re: I did not know that. Rear Wiper - two speed settings.
SausageCreature wrote:
At the risk of exposing myself as slightly dense, just this week I found that the rear wiper on my 2007 3.6 has two speed settings.
The switch only has one position. However, by switching the rear wiper on and before it has completed it's first full sweep across the glass switch it off, and then on again it makes my wiper work in continuous mode rather than the intermittent mode.
You may all already know this, but thought i would share it. I found it be accident, but had I RTFM I probably would have read about it. I just dont see myself ever reading about windscreen wiper operation though, i just take it for granted, on, off, wash, wipe, what could I possible need to read about wipers? Ha.
This feature actually allows you to set the intermittent delay to whatever you want (well, it did on my 2006, haven't tried yet on the SC). Something like, flick the rear wiper on the off, wait for how long you want the delay to be, then flick it back on.
I used to do it without thinking how, bit different when you're trying to remember how when you're not in the car!
Post #509385 21st Mar 2019 12:50am
Full Fattie
We had a Corsa that done that for the front wipers, allowed you to set the delay
Post #509396 21st Mar 2019 7:48am
m@ttsFF
United Kingdom 2016 Range Rover Vogue SE SDV8 Corris Grey
p38arover wrote:
The arrow on the fuel gauge is probably less than 25 years old. My P38A didnt have it as you can see from this pic of my dash.
No arrow - but the nozzle on the fuel pump pic is on the right, which is how it was done pre arrow 4.4 AdBlu Tractor
4.2 SC - sold
Post #509496 21st Mar 2019 9:48pm
kooky_guy
I can't get this to work on my 2010 - it's really annoying as the default interval is too short. 2010 4.4 TDV8 Vogue SE
Post #509752 25th Mar 2019 8:51am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Worked on my 2002 but not on my 2010.
Ian
Post #509754 25th Mar 2019 9:27am
